Chart Graphs in STM32 Cube Monitor
2024-10-13 12:51 PM
I was trying to create a bar chart that represent some PIDs in my OBD2 Emulators Project.
However, in Cube Monitor, I think that when creating chart graphs or line graphs, the Cube Monitor can not provide an option to assign text above every bar in a bar chart or assign a text along each line in a line graph. I believe that the Cube Monitor chart graphs can only provide "legends" and not anything else. It also can not edit the legends to change their text.
Can you confirm this please? If not then can you guide how to achieve assigning text on each bar, if possible?
2024-10-23 1:58 AM
Hello @A2SK2 ,
Even though CubeMonitor Chart is derived from node-red ui chart, it is not possible to assign a label to each bar or each line, neither, I'm afraid, to edit the legends.
