Unable to debug using OpenOCD under STM32CubeIDE
‎2025-06-23 7:28 AM
I am attempting to debug code on a Necleo-U385RG-Q board using STM32CubeIDE V1.18.1 under Windows 11. I beleive that under \plugins\com.st.stm32cube.ide.mcu.externaltools.openocd.win32_2.4.100.202501161620\tools there should be a scripts directory that contains cfg files for ST-Link V3 and my board. However, there is no scripts directory anywhere in the installation. Nor is there for my STM32Cube Programmer installation. When setting up the debug configurations I am able to select ST-Link GDB Server as a debug probe. This does get the board's serial number. However, because of the missing files I expect to see in the scripts directory, I get nothing when selecting ST-Link OpenOCD. I believe I should put the path to the cfg files under OpenOCD options.
STM32CubeIDE
‎2025-06-25 9:45 AM
Hello @EmbStmDev
I was not able to see the same behavior as I am able to debug the code using ST-Link GDB and OpenOCD.
Could you share the log file of the debug?
KR,
Semer.
‎2025-06-25 11:00 AM
The cfg files are under .../plugins/com.st.stm32cube.ide.mcu.debug.openocd_xxxxxxx/resources/openocd/st_scripts
