this question is about Cube_IDE installation failure.
the Cube_IDE version was 1.3.0 .
I tried several recommended method searched in google, But To tell you the conclusion, It did not worked.
The methods I tried and didn't worked:
2020-06-21 8:04 PM
- Just to run 'Cube_IDE installtion file'
ERROR MESSAGE:
NSIS Error
Error launching installer
2. Right clicking the 'Cube_IDE installation file' and clicking 'Run as administrator'
ERROR MESSAGE:
NSIS Error
3. Opening command prompt, go to folder where I installed CUbeIDE, and type ' CubeIDE.exe /NCRC'
(plus, I renamed the installation file 'blah blah blah' to CubeIDE.exe because it is to long)
ERROR MESSAGE:
STMicroelectronics STM32CubeIDE
Error! Can't initialize plug-ins directory. Please try again later.
so I tried different method
different method 1. "Turning off all my firewall protection wile downloading CubeIDE" ----> tried but It didn't really helped with my problem.
different method 2. "To Download 'Cube_IDE installtion file' with my roomate's laptop and move it to my laptop and install" ---> tried but didn't work.
Anyone who knows how to deal with my problems?? thanks.
STM32CubeIDE
2020-06-21 11:16 PM
I SOVE THE PROBLEM
Bytheway, It is not the proper way I think..
I made the another account with my own laptop, log-in to the new account, re-downloaded STM32CubeIDE ver1.3.0, it did work.
2020-06-21 8:09 PM
Installing 'IAR embedded workbench' and 'CubeMX' makes no trouble, But only CubeIDE does make troubles.
My brain, BOOOM
2020-06-21 11:16 PM
I SOVE THE PROBLEM
