Feb 20, 2024 11:29 AM UTC
STM32F103RET7
While testing the code, checked the local and global variables in live expression but it showed " failed to evaluate". and the variables are not refreshing continuously. but if I put a breakpoint it shows the values.
    Andrew Neil
    Feb 20, 2024 11:48 AM UTC
    @NIJASPALAKKAL wrote:
     the code,
    What code?
    You need to show the code that you're talking about!
    Please use this button to properly post source code:
    Screenshots of what you're doing & seeing in the debugger would also help.
    https://www.techrepublic.com/article/how-to-take-screenshots-in-windows-10/
    mƎALLEm
    Feb 20, 2024 11:51 AM UTC
    Which Toolchain? what code? issue with global and local variables?
    Feb 28, 2024 11:38 AM UTC
    For any sample code that is developed in STM32CUBE IDE, I used ADC, and SPI in my project. while fetching the ADC values I was able to display it over live expression. but if I put breakpoints the values are coming else it will be reading like " error to read the values".
