stlink_gdbserver gdb-multiarch
  • March 27, 2025
  • 5 replies
  • 1192 views
I'm trying to debug some embedded rust. I was using openocd (12) and gdb-multiarch. I currently using an stm32f3discovery. I've tried C with eclipse Embedded ARM and STM32CubeIDE and while STM32CubeIDE does work (validating my hardware) nothing else works reliably. I have tried using ST-LINK_gdbserver from the stm32cubeide installation with gdb-multiarch which give much the same results as openocd + gdbmultiarch. Below is a run from rust but C gives much the same results:
I start openocd which listens on :3333
I start gdb-multiarch:
$ gdb-multiarch -q target/thumbv7em-none-eabihf/debug/examples/hello -ex "target extended-remote :3333"
Reading symbols from target/thumbv7em-none-eabihf/debug/examples/hello...
Remote debugging using :3333
0x080005fc in ?? ()
(gdb) b main
Breakpoint 1 at 0x45c: file examples/hello.rs, line 11.
(gdb) c
Continuing.
^C
Program received signal SIGINT, Interrupt.
0x080005fc in ?? ()
(gdb)
beattieAuthor
This is on a Debian bookworm host.
Pavel A.
March 27, 2025
Do you use the ST branch (or fork) of OpenOCD?
beattieAuthor
If your mean https://github.com/STMicroelectronics/OpenOCD I tried that as well in fact I just cloned and built branch openocd-cubeide-r6. I there a different one I could try?
Pavel A.
March 27, 2025
