2019-09-04 11:56 PM
hi all, new to stm32cube ide.
i generated all of the project files using the build in cubemx thing and written my program but when i press compile, make errors out on Startup/startup_stm32f407vgtx.o missing.
i've tried generating the files with a seperate cubemx installation but with the same result.
so i came to the conclusion: either my pc is not doing stuff or i missed a setting.
do you have any suggestions?
thanks in advance!
kars noordhuis
2019-09-05 5:03 AM
Sounds like Linker error. Linker unable to find the object file for the startup code. So is the startup code even compiled?
Can you post your full build console output?
