PH3-BOOT0
‎2023-08-21 4:49 AM
I am using STM32U585RIT6 MCU & I planned to flash the firmware through SWD and onboard debugger module (STLINK-V3MODS) through VCP.
I am having confusion in configuring the PH3-BOOT0 pin.
Should I connect it to 5V or GND.
Or shall I make it No connect.
@RomainR. Can you pls help me on this?
Thanks in advance for any suggestions or help
‎2023-08-21 5:13 AM
Hi @mkm
If you need to boot on the internal flash memory, this pin is set to level LOW (GND) by a pull‑down resistor.
It is possible to put this GPIO to level HIGH to boot on the system flash memory (bootloader), by connecting this pin to VDD.
Diane
‎2023-08-21 5:13 AM
Hi @mkm
Diane
