Old project broken after CubeMX split
BrotherTheo
Hi, so the recent change to make CubeMX a separate app has broken my old project. I am using a Nucleo board and HAL in the project. After a change to the .IOC file I get "stm32h7xx_nucleo_conf.h:50: warning: "USE_NUCLEO_144" redefined".
Is there a resource somewhere explaining to to do all of the after the CubeMX split?
Remove USE_NUCLEO_144 from the preprocessor defines in project properties.
Or ignore it, since it's not preventing compiling from working.
This was an issue before the split as well.
BrotherTheo
Thanks for the response. I'll try it, but a have to point out it worked fine before the split.
BrotherTheo
That did it! Thanks so much!
