How to successfully add an static library to the project and liker in STM32CubeIDE
‎2022-09-23 5:37 PM
I have tried to add a library with .a extension but all tries had been unsuccessfully.
I have added the search path to "Library Search Path (L)" section in MCU GCC Linker.
I have added the library name to "Libraries (-l)" section in MCU GCC Linker.
With this when building the project, I get the next error:
tools\arm-none-eabi\bin\ld.exe: cannot find -lMyLibrary
Is there any other step I'm missing?
Hope you can help me with this.
- Labels:
STM32CubeIDE
‎2022-09-24 8:26 AM
‎2022-09-24 8:26 AM
‎2022-09-24 9:23 PM
Hi Pavel,
Thanks for your reply.
I was missing to set the expected naming convention. adding the prefix "lib" to the .a file solved the problem.
Thanks.
‎2022-09-25 7:41 AM
@DReye.1​ There also is a way to specify library names without prefix 'lib' but I cannot recall it.
