Error importing existing Atollic TrueSTUDIO project to STM32CubeIDE
FCk
Hi.
I'd like to import an existing Atollic TrueSTUDIO project into the STM32CubeIDE. I select "Import...", then exactly "Import Atollic TrueSTUDIO project", specify a folder, but the "Import as" column shows "Convert 'System Workbench for STM32' project to STM32CubeIDE project". Importing the project as proposed produces the invalid orphaned configuration. How can I import the project correctly?
Markus GIRDLAND
Was the project imported into TrueSTUDIO as a System Workbench project?
Does anything work differently if you use "File -> Open Projects from File System..."?
Is it a project you could share so that I could give it a try?
