CubeIDE problems
JerryMC22
Hi boys and girls from ST,
I am testing your CubeIDE and it it catastrophe.
1/ I tried to open a new project in CubeID and I ascertained that I can not add assembly file (s). How I can create project with only one file - in assembly. :)
2/ I tried to close my project in CubeIDE, but the project stayed opened. When I tried to run the already closed project the project was compiled and uploaded to my processor vis STLINK :) it is very cute. Is it a special way defence against an enemy ? :)
3/ Did you consider to connect to MS Visual Studio (VS) developper team and use and to develop VS together with MS people instead of your queer CubeIDE ?
4/ Are you planing to completely rework your CubeMX ? For example the "Clock" configuration picture is really terrible. There is no visual connection to individual registers RCC. It it queer chaos.
Jerry
4 REPLIES 4
Pavel A.
Evangelist III
Have you seen your doctor recently, Mr. Jerry? Do not delay.
I am ok (fully sane) but your product(s) does not work correctly. This is huge problem.
Just to be correct:
- You think, your fully sane.
- (xxx) products not working correctly for you, according to your assessment.
Do not be angry. Not everything is perfect in our world. However, for better imagination I attached seveal images which represents the actual state of your software (i.e. CubeMX and CubeIDE). Your sw is represented by a worker. Enjoy !
My selfie is attached as well. I am chucklig :) Try to discover me. :)
Jerry
