MFawzy
Creating STM32Cube IDE project using command line
  • May 22, 2022
  • 1576 views
Is there a way to create a STM32cube IDE project using command line?
Thanks,
Mohammed
Best answer by Pavel A.
Yes. Look on github, there are IIRC converters from Keil to Eclipse and a CMake generator for Eclipse. They can be adapted for CubeIDE as a variation of Eclipse (but I don't know how exactly).
Pavel A.
Pavel A.Best answer
May 22, 2022
mattias norlander
CubeMX stand-alone also has a CLI interface allowing you to manage projects from CLI:
https://www.st.com/resource/en/user_manual/um1718-stm32cubemx-for-stm32-configuration-and-initialization-c-code-generation-stmicroelectronics.pdf
See chapter 3.3.2.
Stand-alone CubeMX can be used with CubeIDE.
I would probably refrain from modifying the ioc-file inside CubeIDE integrated MX tool while at the same time using the MX CLI tool...
