Cannot update to Cube IDE v.1.13.1
dliky2
Hello everyone,
I have no success in updating Cube IDE 1.13.0 to ver.1.13.1. Each time I try, I receive a message saying that the repositories cannot be found (see attached picture). Different days, same error message. My OS is Windows 11 with a direct Internet connection.
Any clue to solve this issue ?
Thanks a lot,
Emmanuel
dliky2
Hello Issamos,
I finally made a fresh installation of version 1.13.1. Problem is solved. Thanks for your help.
Best regards,
Emmanuel
Issamos
Lead III
Hello @dliky2
I suggest you to take a look on this post.  May the problem is this:
Updating STM32CubeIDE, the post-update restart fails. STM32CubeIDE must be restarted manually.
Else, I suggest you to report your problem directly in the comments of the previous post.
Best regards
II
dliky2
Hello Issamos,
Best regards,
Emmanuel
Hello again
Is good to hear that.
If your case is closed, please mark this answer as best answer to be diffused to everyone.
Best regards.
II
