STM32CubeIDE no more starting
yesterday installed new ide 13.1 , because H563-nucleo board not working with "old" v10.
after some trouble with new "forced login feature" i could make new project from H563 examples.
then i could compile and flash / debug. seem ok so far, then close and shutdown.
then today, start IDE ( on this new workspace) and it cannot start - just "an error has occurred. see log file...metadata.log" .
come on, what now?
i seen a comment, if problem with new v13 , just delete metadata (ok, i moved to other directoty, to be able to use it again.)
then ide starting up, bt no projects found. ok, i "open new..from filesystem" and it is here again.
but now...cannot compile ! -> error " warning: no encoding set .." . hmmm...
close ide.
open again...and voila : "an error has occurred. see log file...metadata.log" .
perfect.
what can i do now ???
