Can't download STM32CubeIDE
eble
Hello all,
I can't download the STM32CubeIDE even as I am registered. There seems to be somthing broken with the Web page. I have tried several browsers. This is what I get, so there is no download button and the table is garbled:
Any help appreciated.
Johannes
35 REPLIES 35
Byxxd
Google chrome breaks links and if you try edge it will happen.
Thank you! turning off all the extensions / ad-blockers helped.
Specifically, the "Hush" extension was causing the issue on my system.
Best and Thanks,
    ~ TG-Techie
lbronco
Still Broken!
CsBe
Every time the same Problem. Cannot download 1.19
green
same, this problem is so annoying i have a project to flash a stm32 blackphill board and cant do *** with this broken server system. Tried everything inlcluding deleting my extensions, switching several broswers still no luck
So where you are?
Maybe it's a problem with the location.
mkes
You can join as "guest" and ST sends you a link that lets you directly download the IDE. I was also stuck in the endless loop. The disabling of extensions also did not work
CsBe
here we go again.. :D
dj99
I have had all of the trouble trying to download and more.  What worked for me this time was to upgrade from the STM32CubeIDE app itself (in windows) using Help|Check for Updates.
acihana
Dear st technical team. Please solve this problem. I tried everything, different browsers, cache clean etc but I couldn't download stm32CubeIDE.
Such problems are unacceptable for a reputable company like St. Dozens of people have been experiencing this problem since 2023, and it continues to happen.
