Build Error for image with custom layer
‎2024-01-06 4:54 PM
I am on part 4 of the digikey embedded linux series and i keep getting this error when running " bitbake custom-image"
# ERROR: /home/matthew/Projects/yocto/meta-custom/recipes-core/images/custom-image.bb: Error during parse shell code, the last 5 lines are: # iterate to the next setting setting=`echo $remaining | cut -d ';' -f1` remaining=`echo $remaining | cut -d ';' -f2-` done WARNING: /home/matthew/Projects/yocto/meta-custom/recipes-core/images/custom-image.bb: Exception during build_dependencies for set_user_group WARNING: /home/matthew/Projects/yocto/meta-custom/recipes-core/images/custom-image.bb: Error during finalise of /home/matthew/Projects/yocto/meta-custom/recipes-core/images/custom-image.bb ERROR: Unable to parse /home/matthew/Projects/yocto/meta-custom/recipes-core/images/custom-image.bb Traceback (most recent call last): File "/home/matthew/Projects/yocto/poky/bitbake/lib/bb/pysh/pyshlex.py", line 600, in PLYLexer._parse(eof=True): elif self._state==self.ST_QUOTED: > self._parse_quoted(eof) elif self._state==self.ST_HEREDOC: File "/home/matthew/Projects/yocto/poky/bitbake/lib/bb/pysh/pyshlex.py", line 688, in PLYLexer._parse_quoted(eof=True): > wtree, remaining = self._wordlexer.add(input, eof) self._wordlexer = None File "/home/matthew/Projects/yocto/poky/bitbake/lib/bb/pysh/pyshlex.py", line 146, in WordLexer.add(data=['"', ' ', ']', ';', ' ', 't', 'h', 'e', 'n', '\n', '\t', '\t', '\t', 'b', 'r', 'e', 'a', 'k', '\n', '\t', '\t', 'f', 'i', '\n', '\t', '\t', '#', ' ', 'i', 't', 'e', 'r', 'a', 't', 'e', ' ', 't', 'o', ' ', 't', 'h', 'e', ' ', 'n', 'e', 'x', 't', ' ', 's', 'e', 't', 't', 'i', 'n', 'g', '\n', '\t', '\t', 's', 'e', 't', 't', 'i', 'n', 'g', '=', '`', 'e', 'c', 'h', 'o', ' ', '$', 'r', 'e', 'm', 'a', 'i', 'n', 'i', 'n', 'g', ' ', '|', ' ', 'c', 'u', 't', ' ', '-', 'd', ' ', "'", ';', "'", ' ', '-', 'f', '1', '`', '\n', '\t', '\t', 'r', 'e', 'm', 'a', 'i', 'n', 'i', 'n', 'g', '=', '`', 'e', 'c', 'h', 'o', ' ', '$', 'r', 'e', 'm', 'a', 'i', 'n', 'i', 'n', 'g', ' ', '|', ' ', 'c', 'u', 't', ' ', '-', 'd', ' ', "'", ';', "'", ' ', '-', 'f', '2', '-', '`', '\n', '\t', 'd', 'o', 'n', 'e', '\n'], eof=True): self._buffer += list(data) > self._parse(eof) File "/home/matthew/Projects/yocto/poky/bitbake/lib/bb/pysh/pyshlex.py", line 324, in WordLexer._parse(eof=True): > read, closed = parsefunc(buf, result, eof) File "/home/matthew/Projects/yocto/poky/bitbake/lib/bb/pysh/pyshlex.py", line 200, in WordLexer._parse_dquote(buf=['\n', '\t', 'd', 'o', 'n', 'e', '\n'], result=['"', ' ]; then\n\t\t\tbreak\n\t\tfi\n\t\t# iterate to the next setting\n\t\tsetting=', ['`', 'echo ', ['$', 'remaining', ''], ' | cut -d ', ["'", ';', "'"], ' -f1', '`'], '\n\t\tremaining=', ['`', 'echo ', ['$', 'remaining', ''], ' | cut -d ', ["'", ';', "'"], ' -f2-', '`'], ''], eof=True): if pos==-1: > raise NeedMore() bb.pysh.pyshlex.NeedMore WARNING: /home/matthew/Projects/yocto/meta-st-stm32mp/recipes-st/images/st-image-vendorfs.bb: Cooker received SIGTERM, shutting down... WARNING: /home/matthew/Projects/yocto/meta-st-stm32mp/recipes-security/optee/optee-os-stm32mp_3.12.0.bb: Cooker received SIGTERM, shutting down... WARNING: Cooker received SIGTERM, shutting down... Summary: There were 5 WARNING messages shown. Summary: There were 2 ERROR messages shown, returning a non-zero exit code.
- Labels:
STM32MP15 Lines
‎2024-01-08 4:30 AM
Hello @BambooEngineer ,
Can you please share directly your image bb file here ? If there is a syntax error as Yocto seems to tell you, it will be easier to catch for me.
Kind regards,
Erwan.
‎2024-01-08 11:08 AM
SUMMARY = "MY CUSTOM LINUX IMAGE."
IMAGE_INSTALL = "packagegroup-core-boot ${CORE_IMAGE_EXTRA_INSTALL}"
IMAGE_LINGUAS = " "
LICENSE = "MIT"
inherit core-image
inherit extrausers
IMAGE_OVERHEAD_FACTOR ?= "1.0"
IMAGE_ROOTFS_SIZE ?= "204800"
EXTRA_USERS_PARAMS = "\ usermod -P 'tacomax' root \"
‎2024-01-09 12:24 AM
@BambooEngineer ,
In this file particularly, I do not see obvious error.
Maybe try to process one by one, removing some parts of your custom files to see where does Yocto see a parsing error. It can either be a little hidden character or an obsolete syntax ("_append" instead of ":append" or things like this).
If you find the line where Yocto crash and you still do not understand why, please let me know.
Kind regards,
Erwan.
