raimondas
Jun 7, 2025 11:44 AM UTC
stm32mp257f-EV1 yocto
Can someone explain how to build own custom yocto linux ?
I have experience with raspberry pi, but stm32mp2 have none normal explanation.
I have cloned from git scarthgap branch of poky, meta-openembedded, meta-st-stm32mp and meta-st-openlinux. Also, I have downloaded stm32mp SDK.
I can't understand if cubemx project for the board is needed ?
if needed how to add it if I have generated it ? I have many years of embedded programming of stm32
I can't find any build machine for bitbake for stm32mp257f-ev1 ?
Overall, trying to build default machine="stm32mp2" gives plenty errors, which I cannot understand.
Maybe someone can provide very direct explanation for building image ?
raimondas
raimondasBest answer
Jun 11, 2025 7:42 PM UTC
Thank You @PatrickF
However provided references not giving any real information on development, just concept. practically documentation is shity.
I have solved in few days but it was to long.
1. Download source code
git clone -b scarthgap https://github.com/yoctoproject/poky.git
git clone -b scarthgap https://git.openembedded.org/meta-openembedded
git clone -b scarthgap https://github.com/STMicroelectronics/meta-st-stm32mp.git
git clone -b scarthgap https://github.com/STMicroelectronics/meta-st-openstlinux.git
2. Make build enviroment
source poky/oe-init-build-env
3. modify local.conf in build → conf
MACHINE = "stm32mp2"
DISTRO ?= "openstlinux-weston"
ACCEPT_EULA_stm32mp2 = "1"
PREFERRED_VERSION_libcamera = "0.3.0"
Here a problems with default libcamera 0.4.0 so it is needed to downgrade
4. modify bblayers.conf in build → conf
BBLAYERS ?= " \
/home/raimondas/poky/meta \
/home/raimondas/poky/meta-poky \
/home/raimondas/poky/meta-yocto-bsp \
/home/raimondas/meta-openembedded/meta-oe \
/home/raimondas/meta-openembedded/meta-multimedia \
/home/raimondas/meta-openembedded/meta-networking \
/home/raimondas/meta-openembedded/meta-python \
/home/raimondas/meta-openembedded/meta-gnome \
/home/raimondas/meta-openembedded/meta-webserver \
/home/raimondas/meta-st-stm32mp \
/home/raimondas/meta-st-openstlinux \
/home/raimondas/build/workspace \
5. modify file name
from
/home/raimondas/meta-st-openstlinux/oe-core/recipes-core/systemd/systemd_255.13.bbappend
to
/home/raimondas/meta-st-openstlinux/oe-core/recipes-core/systemd/systemd_255.18.bbappend
6. build
bitbake st-image-weston
or
bitbake st-image-core #this one only using ssh, it's headless.
7. preparing to flash emmc
cd ~/build/tmp-glibc/deploy/images/stm32mp2
and
STM32_Programmer_CLI -c port=usb1 -w flashlayout_st-image-core/optee/FlashLayout_emmc_stm32mp257f-ev1-optee.tsv
Whats all for basic setup.
I wanted something as core-image-base or minimal, with hdmi/dsi output, but this time it is not supported currently.
PatrickF
Jun 11, 2025 11:32 AM UTC
In order to give better visibility on the answered topics, please click on 'Best Answer' on the reply which solved your issue or answered your question.Tip of the day: Try Sidekick STM32 AI agent
raimondas
raimondasAuthorBest answer
Thank You @PatrickF
BBLAYERS ?= " \
5. modify file name
from
to
6. build
or
and
Jul 3, 2025 7:06 PM UTC
I exactly followed the instructions you mentioned
the build says
I changed the systemd_255.17.bbappend to systemd_255.18.bbappend
ERROR: No recipes in default available for:
../meta-st-openstlinux/oe-core/recipes-core/systemd/systemd_255.18.bbappend
Here is my bblayer
$ cat conf/bblayers.conf
# POKY_BBLAYERS_CONF_VERSION is increased each time build/conf/bblayers.conf
# changes incompatibly
POKY_BBLAYERS_CONF_VERSION = "2"
BBPATH = "${TOPDIR}"
BBFILES ?= ""
BBLAYERS ?= " \
/home/work-dir-stm32mp257f-ev1/poky-manifest-yocto/poky/meta \
/home/work-dir-stm32mp257f-ev1/poky-manifest-yocto/poky/meta-poky \
/home/work-dir-stm32mp257f-ev1/poky-manifest-yocto/poky/meta-yocto-bsp \
/home/work-dir-stm32mp257f-ev1/poky-manifest-yocto/meta-dir/meta-openembedded/meta-oe \
/home/work-dir-stm32mp257f-ev1/poky-manifest-yocto/meta-dir/meta-openembedded/meta-python \
/home/work-dir-stm32mp257f-ev1/poky-manifest-yocto/meta-dir/meta-openembedded/meta-networking \
/home/work-dir-stm32mp257f-ev1/poky-manifest-yocto/meta-dir/meta-openembedded/meta-multimedia \
/home/work-dir-stm32mp257f-ev1/poky-manifest-yocto/meta-dir/meta-openembedded/meta-gnome \
/home/work-dir-stm32mp257f-ev1/poky-manifest-yocto/meta-dir/meta-openembedded/meta-webserver \
/home/work-dir-stm32mp257f-ev1/poky-manifest-yocto/meta-dir/meta-st-openstlinux \
/home/work-dir-stm32mp257f-ev1/poky-manifest-yocto/meta-dir/meta-st-stm32mp \
raimondas
raimondasAuthor
Jul 3, 2025 8:35 PM UTC
Please check if you exactly have scarthgap version of all software. In my case, I had error with 255.13 version, your version is newer 255.17 so you have some differences in downloaded software from github, comparing to my example.
I have done also such builds with newer versions, but was unlucky. So please keep identical to succeed.
Jul 15, 2025 1:38 PM UTC
Hi @raimondas, @PatrickF
I'm trying to understand the NOR Flash boot sequence of stm32mp257f-ev1.
Im using generated FlashLayout_nor-sdcard_stm32mp257f-ev1-optee.tsv to flash the st-image-weston image.
I want to understand how exactly the boot sequence is started and how it reaches to the u-boot (normal-world boot).
I had a pre-work in understanding this boot sequence, I need a clarification on my understanding
The stm32mp2 boards follow arm trusted boot chain. That means TF-A and OPtee will be the FSBL and U-boot will be SSBL.
So during the power on cycle the ROM code initiates the OCTOSPI interface of the Processor in Legacy SPI (MOSI and MISO) mode at HSI/2 = 32MHz speed.
Then it loads the Initial DT + BL2(optee) to SRAM and initialise the CPU clock and DDR.
Once the CPU is initialised, based on the arm-firmware SPI_NOR and SPI_MEM framework and the boot_device.c configuration, the OCTO SPI is configured to QUADSPI in 1-1-4 (QREAD) mode at max speed (133MHz) speed and loads the remaining Boot Loaders to DDR, and after BL32 the processor enters the UBoot (normal world boot). (To be specific i'm using macronix mx66l5xx series.)
I followed these references to understand whatever i explained earlier, please clarify my understanding and exactly how all fits in the boot sequence.
1. NOR Boot - ROM Code WiKi Page
2. boot_device.c configuration file (arm-firmware : github)
3. spi_nor.h (github : arm-firmware)
4. spi_nor.c (github : arm-firmware)
And also please confirm that NOR will be only used for BOOT (That too only till coping the Bootloaders into DDR, after that NOR will not be used for any other operation after normal-world boot).
