Accessing of RCC_XBARxCFGR register in STM32Mp257F-Dk Board
Aks
Dear Sir/Mam
We are encountering an issue with writing values into channels 0–7 of the RCC_XBARxCFGR register at the address offset 0x1018 + 0x4 * x (where x = 0 to 63).We have also observed that Writing to other channels (x = 8 to 63) works as expected and Attempts to write into RCC_XBARxCFGR(0 to 7) result in the debug control exiting and generating an error.
Thanks & Regards
Akshitha Pattem
Zakaria1
Hello @Aks,
Can you provide more details about exactly what you are trying to write to these registers?
BRs,
Zakaria
PatrickF
hi @Aks ,
did you follow sequence as written in RM0457 "Flexclkgen programming flow" ?
Otherwise, you are likely stopping of fooling some of critical bus clocks.
Regards.
Tip of the day: Try Sidekick STM32 AI agent, see here
Dear @PatrickF
@Zakaria1
We are following the flow mentioned in the Flexclkgen programming flow.But we could not use PLL4 FOUTPOSTDIV as input for channels 0–7 of the RCC_XBARxCFGR register.
Thanks & Regards
Akshitha Pattem
