STM32MP135 - Baremetal - Ethernet2
‎2024-01-31 1:38 AM - edited ‎2024-02-05 10:52 PM
I would like to integrate ethernet2 in my bare-metal project. I am aware that not only eth2 pins have to be properly configured, but also a 10th pin of MCP IO expander. However, the eth2 seems to be disabled after all. I am doing the same configuration steps for eth1 and it simply works. The question is, what am I missing? Could it be PMIC?
Best,
J. Schneider
- Labels:
Power
STM32MP13 Lines
‎2024-03-03 11:30 PM
Hello @ravo ,
I hope you are doing well.
5. Adjust the clock configuration for eth2. It should use 50 MHz and probably be configured with HSE.
I don't know how to do this
> If you can't guarantee eth2 source clock being set to 50 MHz, it just won't work. ST Support will tell you no different. In CubeIDE, there is a whole section to adjust the clock configuration. You could just try to configure 50 MHz on eth2 and understand what is actually being changed.
Best
J. Schneider
‎2024-03-03 11:47 PM
Dear @jschneider
I just forgot to initiate IRQ pin, and one clock pin.
Very thanks, I also consulted with ST guy and he prefer to
SYSCFG->PMCSETR |= (1<<25); at end of MX_ETH_Init function. But it did not work.
So I put to place as you suggest and it started working
So Very thanks for your comments.
No I would like to use both eth1 and eth2. And has some problems with initialize driver. (driver library would preffer only single eth). Maybe I need to copy whole nx_stm32_eth_driver.c to new one... I don't find any examples yet, and in documentation is not written.
Do you have working dual eth at one time ?
Best Regards
Radim
‎2024-03-11 12:20 AM - edited ‎2024-03-12 1:39 AM
Hi @ravo ,
I am happy to see your success.
I haven't used both eth interfaces at once in an Azure RTOS app yet. I am going to do so. For now I wanted to finish the initialization. You are correct, you have to modify nx_stm32_eth_driver.c. Reading the NetXDuo manual is probably a good place to start. In my opinion, it all comes down to modifying the IPInstance structure.
If you find a solution, I encourage you to provide a sample instruction, as I will do the same.
Best,
J. Schneider
‎2024-03-19 12:47 AM
Dear @jschneider
I am in contact wit ST support, there is need to modify nx_stm32_eth_driver.c/h - currently support only one interface at time. HAL already have multiple network interface.
I tried to look at driver which has already multiple instances support - nx_ram_network_driver.c/h, located in \STM32Cube_FW_MP13_V1.0.0\Middlewares\ST\netxduo\common\src - but it could be a lot of work.
So I will wait when ST update nx_stm32_eth_driver.c/h
If I will have some news I will post here.
Regards Radim
‎2024-04-12 4:04 AM
Dear @jschneider
Do you have some news ? I have only small update, the support for dual eth should be in next release (2 - 3 months)
Radim
‎2024-04-15 11:13 PM
Hi @ravo
Thank you for your update. For now I have some other priorities. Waiting for the support seems like a better option.
Best,
J. Schneider
- « Previous
- 1
- 2
- Next »
