Interprocess communication buffer swapping
I am working on IPC between M4 and A7 and it works properly using the "logic analyzer" example. I changed it according to my needs but not the buffers.
1 . I could read the data from 3 buffers, but often buffers are swapping. I would like to what causes this problem and how to solve it?
2. When I start IPC, one of the CPU processes goes into 100%. Is it normal for the IPC? and is there anything that I could change to reduce the CPU processes?
Thank you in advance
