“Error: failed to download Segment[0]�?
Populate the target and boot the image example
2022-01-21 11:12 AM
I looked at the other items with the same title but did not see an answer that would help me.
I am using the STM32MP157F-DK2
The demo code was working when box was opened
I tried to run the demo
“Populate the target and boot the image�?
at
https://wiki.st.com/stm32mpu/wiki/Getting_started/STM32MP1_boards/STM32MP157x-DK2
I am using ecosystem release v3.1.0
And
STM32CubeProgrammer 2.9.0
Down load eventually fails with “Error: failed to download Segment[0]�?
Any help on the matter would be appreciated
Below is the Log
10:53:37 : USB speed : High Speed (480MBit/s)
10:53:37 : Manuf. ID : STMicroelectronics
10:53:37 : Product ID : DFU in HS Mode @Device ID /0x500, @Revision ID /0x0000
10:53:37 : SN : 002A001B3438511436383238
10:53:37 : FW version : 0x0110
10:53:37 : Board : --
10:53:37 : Device ID : 0x0500
10:53:48 : Start Embedded Flashing service
10:53:48 : Memory Programming ...
10:53:48 : Opening and parsing file: tf-a-stm32mp157f-dk2-usb.stm32
10:53:48 : File : tf-a-stm32mp157f-dk2-usb.stm32
10:53:48 : Size : 225596 Bytes
10:53:48 : Partition ID : 0x01
10:53:48 : Download in Progress:
10:53:48 : File download complete
10:53:48 : Time elapsed during download operation: 00:00:00.473
10:53:48 : RUNNING Program ...
10:53:48 : PartID: :0x01
10:53:48 : Start operation done successfully at partition 0x01
10:53:48 : Flashlayout Programming ...
10:53:48 : Running Flashlayout Partition ...
10:53:48 : Flashlayout partition started successfully
10:53:48 : Opening and parsing file: fip-stm32mp157f-dk2-trusted.bin
10:53:48 : File : fip-stm32mp157f-dk2-trusted.bin
10:53:48 : Size : 1090807 Bytes
10:53:48 : Partition ID : 0x03
10:53:50 : File download complete
10:53:50 : Time elapsed during download operation: 00:00:01.428
10:53:50 : RUNNING Program ...
10:53:50 : PartID: :0x03
10:53:50 : Reconnecting the device ...
10:53:53 : USB speed : High Speed (480MBit/s)
10:53:53 : Manuf. ID : STMicroelectronics
10:53:53 : Product ID : USB download gadget@Device ID /0x500, @Revision ID /0x2001, @Name /STM32MP157FAC Rev.Z,
10:53:53 : SN : 002A001B3438511436383238
10:53:53 : FW version : 0x0110
10:53:53 : Board : --
10:53:53 : Device ID : 0x0500
10:53:53 : Device name : STM32MP157FAC Rev.Z
10:53:53 : Device type :
10:53:53 : Device CPU :
10:53:53 : Start operation done successfully at partition 0x03
10:53:53 : Memory Programming ...
10:53:53 : Opening and parsing file: tf-a-stm32mp157f-dk2-sdcard.stm32
10:53:53 : File : tf-a-stm32mp157f-dk2-sdcard.stm32
10:53:53 : Size : 225489 Bytes
10:53:53 : Partition ID : 0x04
10:53:53 : Download in Progress:
10:53:56 : Error: failed to download Segment[0]
10:53:56 : Error: failed to download the File
10:53:56 : Error: Download partition 0x04 failed
10:53:56 : Error: TSV flashing service failed
10:53:56 : Warning: Connection to device 0x500 is lost
10:53:56 : Disconnected from device.
STM32MP15 Lines
2022-02-01 12:53 PM
ran it again this time it failed the way it normally does
STM32CubeProgrammer v2.9.0
FW version : 0x0110
Board : --
Device ID : 0x0500
AREA NAME SECT.NBR PARTITION.ID SIZE TYPE
Partition0 0000 0x00000000 0256 KB RW
FSBL 0000 0x00000001 0001 MB RW
Partition2 0000 0x00000002 0001 MB RW
Partition3 0000 0x00000003 0016 MB RW
Partition4 0000 0x00000004 0016 MB RW
virtual 0000 0x000000f1 0512 B R
Device type : MPU
Revision ID : --
Device CPU : Cortex-A7
sending a set alternate setting request with index: 5
receiving packet
UpLoading data
sending a set alternate setting request with index: 1
Partition ID : 0x01
Segment[0] downloaded successfully
Time elapsed during download operation: 00:00:00.503
RUNNING Program ...
PartID: :0x01
sending a dfu end of download request
receiving packet
UpLoading data
sending a set alternate setting request with index: 0
Request detach value = 0
receiving packet
UpLoading data
receiving packet
UpLoading data
sending a set alternate setting request with index: 3
receiving packet
UpLoading data
Partition ID : 0x03
Time elapsed during download operation: 00:00:01.424
RUNNING Program ...
PartID: :0x03
receiving packet
UpLoading data
Request detach value = 1
Reconnecting...
Reconnected
FW version : 0x0110
Board : --
Device ID : 0x0500
Device type : MPU
fsbl1 0000 0x00000004 0256 KB RW
fsbl2 0000 0x00000005 0256 KB RW
fip 0000 0x00000006 0004 MB RW
boot 0000 0x00000010 0064 MB RW
vendorfs 0000 0x00000011 0016 MB RW
rootfs 0000 0x00000012 0744 MB RW
userfs 0000 0x00000013 14364 MB RW
virtual 0000 0x000000f1 0512 B RW
OTP 0000 0x000000f2 1024 B RW
PMIC 0000 0x000000f4 0008 B RW
sending a set alternate setting request with index: 7
receiving packet
UpLoading data
Partition ID : 0x04
Time elapsed during download operation: 00:00:00.072
RUNNING Program ...
PartID: :0x04
receiving packet
UpLoading data
Start operation done successfully at partition 0x04
receiving packet
UpLoading data
Partition ID : 0x05
Error occured while downloading data
Status: errUNKNOWN, State: dfuERROR
Error: Download partition 0x05 failed
2022-02-02 1:19 AM
Hi @JAmia.1 ,
Thank you for your log.
One more test, please can you try again the same command, but by replacing the file at the end of the command line with the file that I attached to my post.
The goal of this test is to flash during the two first steps, two files from 157c instead of 157f because 157c tf-a/fip are running at 650MHz.
Please send me the traces and tell me if it works.
KEvin
2022-02-02 10:53 AM
ogrammer_CLI -c port=usb1 -vb 2 -w flashlayout_st-image-weston/trusted/FlashLayout_sdcard_stm32mp157f-dk2-trusted_test_.tsv
FW version : 0x0110
Board : --
Device ID : 0x0500
Device type : MPU
Revision ID : --
receiving packet
UpLoading data
Opening and parsing file: tf-a-stm32mp157c-dk2-usb.stm32
File : tf-a-stm32mp157c-dk2-usb.stm32
Partition ID : 0x01
Time elapsed during download operation: 00:00:00.568
RUNNING Program ...
PartID: :0x01
receiving packet
UpLoading data
receiving packet
UpLoading data
receiving packet
UpLoading data
receiving packet
UpLoading data
Opening and parsing file: fip-stm32mp157c-dk2-trusted.bin
File : fip-stm32mp157c-dk2-trusted.bin
Partition ID : 0x03
Time elapsed during download operation: 00:00:01.464
RUNNING Program ...
PartID: :0x03
receiving packet
UpLoading data
Reconnecting...
Reconnected
FW version : 0x0110
Board : --
Device ID : 0x0500
Device type : MPU
receiving packet
UpLoading data
Partition ID : 0x04
RUNNING Program ...
PartID: :0x04
receiving packet
UpLoading data
receiving packet
UpLoading data
Partition ID : 0x05
Time elapsed during download operation: 00:00:00.083
2022-02-02 10:55 AM
RUNNING Program ...
PartID: :0x05
receiving packet
UpLoading data
sending a set alternate setting request with index: 2
Start operation done successfully at partition 0x05
receiving packet
UpLoading data
Partition ID : 0x06
Time elapsed during download operation: 00:00:00.391
RUNNING Program ...
PartID: :0x06
receiving packet
UpLoading data
Start operation done successfully at partition 0x06
receiving packet
UpLoading data
Opening and parsing file: st-image-bootfs-openstlinux-weston-stm32mp1.ext4
File : st-image-bootfs-openstlinux-weston-stm32mp1.ext4
Partition ID : 0x10
Time elapsed during download operation: 00:00:33.349
RUNNING Program ...
PartID: :0x10
receiving packet
UpLoading data
sending a set alternate setting request with index: 4
Start operation done successfully at partition 0x10
receiving packet
UpLoading data
Opening and parsing file: st-image-vendorfs-openstlinux-weston-stm32mp1.ext4
File : st-image-vendorfs-openstlinux-weston-stm32mp1.ext4
Partition ID : 0x11
Time elapsed during download operation: 00:00:08.599
RUNNING Program ...
PartID: :0x11
receiving packet
UpLoading data
Start operation done successfully at partition 0x11
receiving packet
UpLoading data
Opening and parsing file: st-image-weston-openstlinux-weston-stm32mp1.ext4
File : st-image-weston-openstlinux-weston-stm32mp1.ext4
Partition ID : 0x12
Time elapsed during download operation: 00:05:29.957
RUNNING Program ...
PartID: :0x12
receiving packet
UpLoading data
sending a set alternate setting request with index: 6
Start operation done successfully at partition 0x12
receiving packet
UpLoading data
Opening and parsing file: st-image-userfs-openstlinux-weston-stm32mp1.ext4
File : st-image-userfs-openstlinux-weston-stm32mp1.ext4
Partition ID : 0x13
Time elapsed during download operation: 00:01:07.174
RUNNING Program ...
PartID: :0x13
receiving packet
UpLoading data
Start operation done successfully at partition 0x13
receiving packet
UpLoading data
Flashing service completed successfully
2022-02-02 11:01 AM
That worked. had to enter log in two parts as it was to large.
Also note I changed the file name to _test_ as the command line did not like (test)
don't know if its worth repeating but
the file 157d-dk1- worked using the cube programmer
2022-02-03 2:04 AM
Hello @JAmia.1 ,
We identified an issue with 1 or 2 faulty boards, out of the box, with the same symptoms than yours, when running at 800MHz.
- The problem never happens if you are using the file from 157c-dk2 instead of 157f-dk2 because they are running at 650Mhz.
- Or it is possible to use the board without the screen even at 800MHz, what you have done by using the files 157d-dk1.
Unfortunately, you have to contact your supplier to have your board replaced.
Or you can continue to use it, but with 157c-dk2 files only.
Kevin
2023-02-13 1:25 AM
I had the same issue in the STM32CubeProgrammer, but solved it somehow in another way:
In Erasing & Programming tab:
- Uncheck "skip flash erase before programming".
- Click Start programming. (This also failed for me)
- Recheck "skip flash erase before..."
- Start programming (this was successful)
- « Previous
- 1
- 2
- Next »
