2022-07-07 3:29 AM
Hello:
I installed 'cups' and 'hplip', and successfully installed HP_ LaserJet_ 1010 driver through 'hp-setup', but when I print files through 'lp', the printer doesn't respond, and a 'filter failed' error occurs. I want to install hplip-3.19.12-plugin_run, but failed. This is the error log:
D [07/Jul/2022:10:02:12 +0000] [Job 6] Started filter /usr/libexec/cups/filter/texttopdf (PID 903)
D [07/Jul/2022:10:02:12 +0000] [Job 6] Started filter /usr/libexec/cups/filter/pdftopdf (PID 904)
D [07/Jul/2022:10:02:12 +0000] [Job 6] Started filter /usr/libexec/cups/filter/gstoraster (PID 905)
D [07/Jul/2022:10:02:12 +0000] [Job 6] Started filter /usr/libexec/cups/filter/hpcups (PID 906)
D [07/Jul/2022:10:02:12 +0000] [Job 6] Started backend /usr/libexec/cups/backend/hp (PID 907)
D [07/Jul/2022:10:02:12 +0000] [Job 6] Restarted by "root".
D [07/Jul/2022:10:02:12 +0000] [Job 6] Page = 612x792; 12,12 to 600,780
D [07/Jul/2022:10:02:12 +0000] [Job 6] OUTFORMAT=\"(null)\", so output format will be CUPS/PWG Raster
D [07/Jul/2022:10:02:12 +0000] [Job 6] pdftopdf: Last filter determined by the PPD: hpcups; FINAL_CONTENT_TYPE: application/vnd.cups-raster => pdftopdf will not log pages in page_log.
D [07/Jul/2022:10:02:12 +0000] [Job 6] No viable font found
D [07/Jul/2022:10:02:12 +0000] [Job 6] Set job-printer-state-message to "Ignored bad font \"monospace\"", current level=WARN
D [07/Jul/2022:10:02:12 +0000] [Job 6] PID 903 (/usr/libexec/cups/filter/texttopdf) exited with no errors.
D [07/Jul/2022:10:02:12 +0000] [Job 6] PDF interactive form and annotation flattening done via QPDF
D [07/Jul/2022:10:02:12 +0000] [Job 6] PID 904 (/usr/libexec/cups/filter/pdftopdf) exited with no errors.
D [07/Jul/2022:10:02:12 +0000] [Job 6] Color Manager: Calibration Mode/Off
D [07/Jul/2022:10:02:12 +0000] [Job 6] WARN: not compiled with DBus support
D [07/Jul/2022:10:02:12 +0000] [Job 6] Color Manager: no profiles specified in PPD
D [07/Jul/2022:10:02:12 +0000] [Job 6] Color Manager: ICC Profile: None
D [07/Jul/2022:10:02:12 +0000] [Job 6] Ghostscript using Any-Part-of-Pixel method to fill paths.
D [07/Jul/2022:10:02:12 +0000] [Job 6] Ghostscript command line: /usr/bin/gs -dQUIET -dPARANOIDSAFER -dNOPAUSE -dBATCH -dNOINTERPOLATE -dNOMEDIAATTRS -dShowAcroForm -sstdout=%stderr -sOutputFile=%stdout -sDEVICE=cups -sMediaType=Plain -sOutputType=0 -r600x600 -dMediaPosition=7 -dDEVICEWIDTHPOINTS=612 -dDEVICEHEIGHTPOINTS=792 -dcupsBitsPerColor=1 -dcupsColorOrder=0 -dcupsColorSpace=3 -dcupsRowCount=1 -dcupsRowStep=2 -scupsPageSizeName=Letter -I/usr/share/cups/fonts -c \'<</.HWMargins[12.000000 12.000000 12.000000 12.000000] /Margins[0 0]>>setpagedevice\' -f -_
D [07/Jul/2022:10:02:12 +0000] [Job 6] envp[0]=\"CUPS_CACHEDIR=/var/cache/cups\"
D [07/Jul/2022:10:02:12 +0000] [Job 6] envp[1]=\"CUPS_DATADIR=/usr/share/cups\"
D [07/Jul/2022:10:02:12 +0000] [Job 6] envp[2]=\"CUPS_DOCROOT=/usr/share/doc/cups\"
D [07/Jul/2022:10:02:12 +0000] [Job 6] envp[3]=\"CUPS_FONTPATH=/usr/share/cups/fonts\"
D [07/Jul/2022:10:02:12 +0000] [Job 6] envp[4]=\"CUPS_REQUESTROOT=/var/spool/cups\"
D [07/Jul/2022:10:02:12 +0000] [Job 6] envp[5]=\"CUPS_SERVERBIN=/usr/libexec/cups\"
D [07/Jul/2022:10:02:12 +0000] [Job 6] envp[6]=\"CUPS_SERVERROOT=/etc/cups\"
D [07/Jul/2022:10:02:12 +0000] [Job 6] envp[7]=\"CUPS_STATEDIR=/var/run/cups\"
D [07/Jul/2022:10:02:12 +0000] [Job 6] envp[8]=\"HOME=/var/spool/cups/tmp\"
D [07/Jul/2022:10:02:12 +0000] [Job 6] envp[9]=\"PATH=/usr/libexec/cups/filter:/usr/bin:/usr/sbin:/bin:/usr/bin\"
D [07/Jul/2022:10:02:12 +0000] [Job 6] envp[10]=\"SERVER_ADMIN=root@ATK-MP157\"
D [07/Jul/2022:10:02:12 +0000] [Job 6] envp[11]=\"SOFTWARE=CUPS/2.3.1\"
D [07/Jul/2022:10:02:12 +0000] [Job 6] envp[12]=\"TMPDIR=/var/spool/cups/tmp\"
D [07/Jul/2022:10:02:12 +0000] [Job 6] envp[13]=\"USER=root\"
D [07/Jul/2022:10:02:12 +0000] [Job 6] envp[14]=\"CUPS_MAX_MESSAGE=2047\"
D [07/Jul/2022:10:02:12 +0000] [Job 6] envp[15]=\"CUPS_SERVER=/var/run/cups/cups.sock\"
D [07/Jul/2022:10:02:12 +0000] [Job 6] envp[16]=\"CUPS_ENCRYPTION=IfRequested\"
D [07/Jul/2022:10:02:12 +0000] [Job 6] envp[17]=\"IPP_PORT=631\"
D [07/Jul/2022:10:02:12 +0000] [Job 6] envp[18]=\"CHARSET=utf-8\"
D [07/Jul/2022:10:02:12 +0000] [Job 6] envp[19]=\"LANG=en_US.UTF-8\"
D [07/Jul/2022:10:02:12 +0000] [Job 6] envp[20]=\"PPD=/etc/cups/ppd/hp_LaserJet_1010.ppd\"
D [07/Jul/2022:10:02:12 +0000] [Job 6] envp[21]=\"RIP_MAX_CACHE=128m\"
D [07/Jul/2022:10:02:12 +0000] [Job 6] envp[22]=\"CONTENT_TYPE=text/plain\"
D [07/Jul/2022:10:02:12 +0000] [Job 6] envp[23]=\"DEVICE_URI=hp:/usb/hp_LaserJet_1010?serial=00CNFG454736\"
D [07/Jul/2022:10:02:12 +0000] [Job 6] envp[24]=\"PRINTER_INFO=hp LaserJet 1010 Device (Automatically setup by HPLIP)\"
D [07/Jul/2022:10:02:12 +0000] [Job 6] envp[25]=\"PRINTER_LOCATION=\"
D [07/Jul/2022:10:02:12 +0000] [Job 6] envp[26]=\"PRINTER=hp_LaserJet_1010\"
D [07/Jul/2022:10:02:12 +0000] [Job 6] envp[27]=\"PRINTER_STATE_REASONS=none\"
D [07/Jul/2022:10:02:12 +0000] [Job 6] envp[28]=\"CUPS_FILETYPE=document\"
D [07/Jul/2022:10:02:12 +0000] [Job 6] envp[29]=\"FINAL_CONTENT_TYPE=application/vnd.cups-raster\"
D [07/Jul/2022:10:02:12 +0000] [Job 6] envp[30]=\"AUTH_INFO_REQUIRED=none\"
D [07/Jul/2022:10:02:12 +0000] [Job 6] Start rendering...
D [07/Jul/2022:10:02:12 +0000] [Job 6] Processing page 1...
D [07/Jul/2022:10:02:12 +0000] [Job 6] prnt/backend/hp.c 919: ERROR: null print job total=0
D [07/Jul/2022:10:02:12 +0000] [Job 6] PID 907 (/usr/libexec/cups/backend/hp) exited with no errors.
D [07/Jul/2022:10:02:12 +0000] [Job 6] PID 906 (/usr/libexec/cups/filter/hpcups) crashed on signal 11.
D [07/Jul/2022:10:02:12 +0000] [Job 6] Hint: Try setting the LogLevel to "debug" to find out more.
D [07/Jul/2022:10:02:12 +0000] [Job 6] Processing page 2...
D [07/Jul/2022:10:02:12 +0000] [Job 6] Rendering completed
D [07/Jul/2022:10:02:12 +0000] [Job 6] PID 905 (/usr/libexec/cups/filter/gstoraster) exited with no errors.
D [07/Jul/2022:10:02:12 +0000] [Job 6] End of messages
D [07/Jul/2022:10:02:12 +0000] [Job 6] printer-state=3(idle)
D [07/Jul/2022:10:02:12 +0000] [Job 6] printer-state-message="Rendering completed"
D [07/Jul/2022:10:02:12 +0000] [Job 6] printer-state-reasons=none
Please help me. Thanks.
2022-07-07 7:40 AM
Hi @zxiao.4
The hplip-3.19.12-plugin.run is a HP proprietary package and is not available in the stm32mpu ecosystem. You have to install it by yourself or request help from HP support.
This link may help you:
https://developers.hp.com/hp-linux-imaging-and-printing/binary_plugin.html
Best regards,
--JM
2022-07-07 4:08 AM
Hi @zxiao.4,
At first sight, this issue looks to me unrelated to STM32MP157 Soc or USB integration.
I suggest you rather try to find help in CUPS community.
As a simple clue, I would start to check what means "No viable font found" and if it can explain the failure.
eg that post which looks to treat about a similar problem
print text file fails with "no usable font available" · Issue #5165 · apple/cups (github.com)
Hope it help
Olivier
2022-07-07 4:40 AM
Ok ,thanks.
2022-07-07 5:16 AM
when I 'apt-get install hplip-* ' ,
Reading package lists... Done
Building dependency tree
Reading state information... Done
E: Unable to locate package hplip-3.19.12-plugin.run
E: Couldn't find any package by glob 'hplip-3.19.12-plugin.run'
E: Couldn't find any package by regex 'hplip-3.19.12-plugin.run'
E: Unable to locate package hplip-3.19.12-plugin.run.asc
E: Couldn't find any package by glob 'hplip-3.19.12-plugin.run.asc'
E: Couldn't find any package by regex 'hplip-3.19.12-plugin.run.asc'
How can I install hplip-3.19.12-plugin.run? My printer needs this driver.
2022-07-07 7:40 AM
Hi @zxiao.4
Best regards,
--JM
2022-07-07 4:05 PM
Ok,thanks.
