2024-03-21 3:09 PM - edited 2024-03-21 8:55 PM
i'm trying to compile kernel from Ecosystem 4.1 , i'm downloading :
https://www.st.com/en/embedded-software/stm32mp1dev.html#get-software
... version 4.1.0, kernel is linux-stm32mp-5.15.67-stm32mp-r2-r0/linux-5.15.67
error from compilation :
HOSTCC scripts/dtc/util.o
LEX scripts/dtc/dtc-lexer.lex.c
YACC scripts/dtc/dtc-parser.tab.[ch]
HOSTCC scripts/dtc/yamltree.o
scripts/dtc/yamltree.c:9:10: fatal error: yaml.h: No such file or directory
9 | #include <yaml.h>
compilation terminated.
make[1]: *** [scripts/Makefile.host:112: scripts/dtc/yamltree.o] Error 1
make[1]: *** Waiting for unfinished jobs....
make: *** [Makefile:1458: scripts_dtc] Error 2
it seems that there is missing support for yaml in SDK stm32mp1-openstlinux-5.15-yocto-kirkstone-mp1-v22.11.23, in directory x86_64-ostl_sdk-linux,
is there a way how to append yaml support into x86_64-ostl_sdk-linux ? or is ecosystem 4.1 not compilable ?
Kind regards,
2024-03-22 8:19 AM
problem solved,
i started again from clean and it's successfully compiling ...
possibly issue occurred because i tried other versions of Developer package and i forgot to refresh environment to different SDK ... case closed ...
2024-03-22 8:19 AM
problem solved,
