Can you recommend a microprocessor not a microcontroller for an electric vehicle applications? I need to design an ECU containing microprocessor to connect to front/rear led of an EV.
CG.2
?? You need Linux/VxWorks to drive LEDs ??
Look at what others use for ECU, Infotainment and V2X..
This reminds me of a marketing material on glossy paper I've been given some 20 years ago, where an unnamed leading German chipmaker started the presentation with something like "there are at least 100 microcontrollers in a modern mid-range car", to continue explaining how to properly select the 3 microcontrollers necessary to control one side mirror.
