How to debug M4 firmware based on "st_image_core" using the EV1 board?
‎2020-03-30 1:39 AM
hello all
i have a STM32MP157C-EV1, and I want to build an m4 core development and debugging environment in minimal "st-image-core".
M4 firmware created using "STM32CudeIDE" can be debugged in "st-image-weston", but an error occurs in "st-image-core".
​What items should be added to "st-image-core.bb" to work normally?
error message :
[ 100.552483] remoteproc remoteproc0: powering up m4
[ 100.555897] remoteproc remoteproc0: Direct firmware load for OpenAMP_TTY_echo_CM4.elf failed with error -2
[ 100.571270] remoteproc remoteproc0: request_firmware failed: -2
[ 100.575829] remoteproc remoteproc0: Boot failed: -2
I will wait for your reply.
STM32MP15 Lines
‎2020-04-06 5:49 AM
Hi @Machilus​
I can not figure out why remote proc browse so many folders ?
What is the structure of the /lib/firmware on your target ?
Where /lib/firmware/updates/4.19.94/ come from ?
Where is the OpenAMP_TTY_echo_CM4.elf exactly before you start the firmware ?
If I got it right it's working with "st-image-weston". Can you share the succeeded trace of firmware start ?
Any difference in /lib/firmware folder structure ?
Hope it help,
Olivier
‎2020-03-30 2:33 AM
Hi @Machilus​ ,
By comparing with st-image-weston.bb, I guess adding "eclipe-debug" in IMAGE_FEATURES looks to be good candidate.
I will ask for confirmation from expert.
Does your traces come from a Debug session from STM32CubeIDE or a manual start of firmware from Linux ?
Olivier
‎2020-03-30 5:14 PM
‎2020-03-31 5:26 PM
Hi ​ @OlivierG (ST Employee)
Thank you for your reply.
Tracking is a kernel message when executing a debug session of "STM32CubeIDE".
Adding "eclipse-debug" to "st-image-core.bb" has not solved the problem.
IMAGE_FEATURES += "\
package-management \
ssh-server-dropbear \
eclipse-debug \
‎2020-04-01 1:33 AM
Hi @Machilus​
Your initial trace show an error due to fact that firmware is missing in /lib/firmware
STM32CubeIDE is using ethernet connection to copy the .elf to the target.
Ethernet service may likely miss in st-image-core ( check on going at my end)
Did you noticed something wrong during download of .elf with STM32CubeIDE ?
Could you try manual copy and start of firmware on target using this
Thanks for feedback
Olivier
‎2020-04-02 2:38 AM
No download problems using "STM32CubeIDE".
When manually running firmware in the manner OlivierG suggested,
the following problems occurred.
<< Execution Message >>
root@stm32mp1-fiscal:/lib# echo start >/sys/class/remoteproc/remoteproc0/state
[ 1090.457191] remoteproc remoteproc0: powering up m4
[ 1090.460584] remoteproc remoteproc0: loading /lib/firmware/updates/4.19.94/FISCAL_CM4.elf failed with error -20
[ 1090.474820] remoteproc remoteproc0: loading /lib/firmware/updates/FISCAL_CM4.elf failed with error -20
[ 1090.484713] remoteproc remoteproc0: loading /lib/firmware/4.19.94/FISCAL_CM4.elf failed with error -20
[ 1090.494670] remoteproc remoteproc0: loading /lib/firmware/FISCAL_CM4.elf failed with error -20
[ 1090.503785] remoteproc remoteproc0: Direct firmware load for FISCAL_CM4.elf failed with error -20
[ 1090.511210] remoteproc remoteproc0: request_firmware failed: -20
[ 1090.520436] remoteproc remoteproc0: Boot failed: -20
<<Below is a message from OpenOCD using ST-LINK.>>
Open On-Chip Debugger 0.10.0+dev-01193-g5ce997d (2020-02-20-10:54)
Licensed under GNU GPL v2
For bug reports, read
http://openocd.org/doc/doxygen/bugs.html
cortex_a interrupt mask on
cortex_a domain access control fixup on
none separate
adapter speed: 8000 kHz
adapter_nsrst_assert_width: 200
adapter_nsrst_delay: 200
none srst_pulls_trst
srst_only srst_pulls_trst srst_gates_jtag srst_open_drain connect_deassert_srst
Info : Listening on port 6666 for tcl connections
Info : Listening on port 4444 for telnet connections
Info : STLINK V3J6M2B4S1 (API v3) VID:PID 0483:374F
Info : using stlink api v3
Info : Target voltage: 3.238171
Info : clock speed 8000 kHz
Info : SRST line released
Info : stlink_connect(connect)
Info : SWD DPIDR 0x6ba02477
Info : STM32MP151CAAx.cpu0: hardware has 6 breakpoints, 4 watchpoints
Error: Could not find MEM-AP to control the core
Info : Listening on port 3334 for gdb connections
Info : Listening on port 3333 for gdb connections
ap 0 selected, csw 0x10006000
Info : accepting 'gdb' connection on tcp/3333
Error: Target not examined yet
Info : New GDB Connection: 1, Target STM32MP157CAAx.cpu2, state: unknown
undefined debug reason 7 - target needs reset
Thank you for your interest in this problem.
‎2020-04-02 3:02 AM
​Hi @Machilus​
I noticed very strange/abnormal traces in your OpenOCD log :
Definitly not matching an EV1 board !?
Can you clarify your setup ?
For which target did you compile the .elf ?
For manual start of firmware can you confirm the firmware is well present in /lib/firmware ?
Olivier
‎2020-04-03 1:26 AM
Sorry.​
I sent the wrong message.
It was a message from a custom board made from a "STM32MP151C" chip based on the "STM32MP157C-EV1" board.
Recently, I debugging "OpenAMP_TTY_echo" firmware from created a "st-image-core" distribution on the "EV1" Board.
​It worked without error.
However, running the M4 firmware on the custom board based on "STM32MP151C" resulted in an error.
​This error does not occur in the "st-image-weston" distribution,
Error occurs only in "st-image-core" distribution.
<<Below is a message from OpenOCD using ST-LINK V3SET>>
none separate
Info : Target voltage: 3.234990
Info : New GDB Connection: 1, Target STM32MP151CAAx.cpu2, state: unknown
root@stm32mp1-fiscal:~# echo start > /sys/class/remoteproc/remoteproc0/state
[ 489.401238] remoteproc remoteproc0: powering up m4
[ 489.404634] remoteproc remoteproc0: loading /lib/firmware/updates/4.19.94/OpenAMP_TTY_echo_CM4.elf failed with error -20
[ 489.418946] remoteproc remoteproc0: loading /lib/firmware/updates/OpenAMP_TTY_echo_CM4.elf failed with error -20
[ 489.429594] remoteproc remoteproc0: loading /lib/firmware/4.19.94/OpenAMP_TTY_echo_CM4.elf failed with error -20
[ 489.440258] remoteproc remoteproc0: loading /lib/firmware/OpenAMP_TTY_echo_CM4.elf failed with error -20
[ 489.450382] remoteproc remoteproc0: Direct firmware load for OpenAMP_TTY_echo_CM4.elf failed with error -20
[ 489.460633] remoteproc remoteproc0: request_firmware failed: -20
[ 489.467095] remoteproc remoteproc0: Boot failed: -20
machilus
‎2020-04-06 5:49 AM
Hi @Machilus​
Hope it help,
Olivier
‎2020-04-06 6:46 PM
I solved this problem.
In "st-image-core", "/lib/firmware" is a file.
In "st-image-weston", "/lib/firmware" is a directory.
In "st-image-core," I solved the problem by making "/lib/firmware" a directory.
Naturally, firmware exists within the "/lib/firmware" directory.
Thank you for helping me solve the problem.
Best regards.
Machilus.
