glib meson error: ERROR: <ExternalProgram 'python3' is not a valid python or it is missing setuptools
2021-08-16 1:50 PM
I have been trying to compile an image in Yocto with a custom machine to load my own device tree, but when trying to compile I always get the same error, here is a log:
Log data follows:
| DEBUG: Executing shell function do_configure
| gtkdocize: neither configure.ac nor configure.in exist
| NOTE: Executing meson -Dgtk_doc=false -Ddtrace=false -Dfam=false -Dsystemtap=false -Dselinux=disabled -Dlibmount=true -Dman=false -Dinternal_pcre=false -Dinstalled_tests=false --cross-file=/home/fpinilla/STM32MP15-Ecosystem-v3.0.0/Distribution-Package/layers/poky/meta/recipes-core/glib-2.0/glib-2.0/meson.cross.d/common-linux --cross-file=/home/fpinilla/STM32MP15-Ecosystem-v3.0.0/Distribution-Package/layers/poky/meta/recipes-core/glib-2.0/glib-2.0/meson.cross.d/common-glibc --cross-file=/home/fpinilla/STM32MP15-Ecosystem-v3.0.0/Distribution-Package/layers/poky/meta/recipes-core/glib-2.0/glib-2.0/meson.cross.d/common...
| The Meson build system
| Version: 0.53.2
| Source dir: /home/fpinilla/STM32MP15-Ecosystem-v3.0.0/Distribution-Package/build-openstlinuxweston-stm32mp1-mx-sidacam/tmp-glibc/work/cortexa7t2hf-neon-vfpv4-ostl-linux-gnueabi/glib-2.0/1_2.62.6-r0/glib-2.62.6
| Build dir: /home/fpinilla/STM32MP15-Ecosystem-v3.0.0/Distribution-Package/build-openstlinuxweston-stm32mp1-mx-sidacam/tmp-glibc/work/cortexa7t2hf-neon-vfpv4-ostl-linux-gnueabi/glib-2.0/1_2.62.6-r0/build
| Build type: cross build
| Project name: glib
| Project version: 2.62.6
| C compiler for the build machine: gcc (gcc 9.3.0 "gcc (Ubuntu 9.3.0-17ubuntu1~20.04) 9.3.0")
| C linker for the build machine: gcc ld.bfd 2.34
| C++ compiler for the build machine: g++ (gcc 9.3.0 "g++ (Ubuntu 9.3.0-17ubuntu1~20.04) 9.3.0")
| C++ linker for the build machine: g++ ld.bfd 2.34
| C compiler for the host machine: arm-ostl-linux-gnueabi-gcc -mthumb -mfpu=neon-vfpv4 -mfloat-abi=hard -mcpu=cortex-a7 --sysroot=/home/fpinilla/STM32MP15-Ecosystem-v3.0.0/Distribution-Package/build-openstlinuxweston-stm32mp1-mx-sidacam/tmp-glibc/work/cortexa7t2hf-neon-vfpv4-ostl-linux-gnueabi/glib-2.0/1_2.62.6-r0/recipe-sysroot (gcc 9.3.0 "arm-ostl-linux-gnueabi-gcc (GCC) 9.3.0")
| C linker for the host machine: arm-ostl-linux-gnueabi-gcc -mthumb -mfpu=neon-vfpv4 -mfloat-abi=hard -mcpu=cortex-a7 --sysroot=/home/fpinilla/STM32MP15-Ecosystem-v3.0.0/Distribution-Package/build-openstlinuxweston-stm32mp1-mx-sidacam/tmp-glibc/work/cortexa7t2hf-neon-vfpv4-ostl-linux-gnueabi/glib-2.0/1_2.62.6-r0/recipe-sysroot ld.bfd 2.34.0.20200220
| C++ compiler for the host machine: arm-ostl-linux-gnueabi-g++ -mthumb -mfpu=neon-vfpv4 -mfloat-abi=hard -mcpu=cortex-a7 --sysroot=/home/fpinilla/STM32MP15-Ecosystem-v3.0.0/Distribution-Package/build-openstlinuxweston-stm32mp1-mx-sidacam/tmp-glibc/work/cortexa7t2hf-neon-vfpv4-ostl-linux-gnueabi/glib-2.0/1_2.62.6-r0/recipe-sysroot (gcc 9.3.0 "arm-ostl-linux-gnueabi-g++ (GCC) 9.3.0")
| C++ linker for the host machine: arm-ostl-linux-gnueabi-g++ -mthumb -mfpu=neon-vfpv4 -mfloat-abi=hard -mcpu=cortex-a7 --sysroot=/home/fpinilla/STM32MP15-Ecosystem-v3.0.0/Distribution-Package/build-openstlinuxweston-stm32mp1-mx-sidacam/tmp-glibc/work/cortexa7t2hf-neon-vfpv4-ostl-linux-gnueabi/glib-2.0/1_2.62.6-r0/recipe-sysroot ld.bfd 2.34.0.20200220
| Found pkg-config: /home/fpinilla/STM32MP15-Ecosystem-v3.0.0/Distribution-Package/build-openstlinuxweston-stm32mp1-mx-sidacam/tmp-glibc/work/cortexa7t2hf-neon-vfpv4-ostl-linux-gnueabi/glib-2.0/1_2.62.6-r0/recipe-sysroot-native/usr/bin/pkg-config (0.29.2)
| Run-time dependency libpcre found: YES 8.44
| Library m found: YES
| Run-time dependency libffi found: YES 3.3
| Run-time dependency zlib found: YES 1.2.11
| Checking for function "ngettext" : YES
| Checking for function "bind_textdomain_codeset" : YES
| Run-time dependency mount found: YES 2.35.1
| Dependency libselinux skipped: feature selinux disabled
| Checking for function "getxattr" : YES
| Has header "sys/xattr.h" : YES
| Checking if "XATTR_NOFOLLOW" compiles: NO
| Checking for function "strlcpy" : NO
| Program python3 found: YES (/home/fpinilla/STM32MP15-Ecosystem-v3.0.0/Distribution-Package/build-openstlinuxweston-stm32mp1-mx-sidacam/tmp-glibc/work/cortexa7t2hf-neon-vfpv4-ostl-linux-gnueabi/glib-2.0/1_2.62.6-r0/recipe-sysroot-native/usr/bin/python3-native/python3)
| meson.build:1999:0: ERROR: <ExternalProgram 'python3' -> ['/home/fpinilla/STM32MP15-Ecosystem-v3.0.0/Distribution-Package/build-openstlinuxweston-stm32mp1-mx-sidacam/tmp-glibc/work/cortexa7t2hf-neon-vfpv4-ostl-linux-gnueabi/glib-2.0/1_2.62.6-r0/recipe-sysroot-native/usr/bin/python3-native/python3']> is not a valid python or it is missing setuptools
| A full log can be found at /home/fpinilla/STM32MP15-Ecosystem-v3.0.0/Distribution-Package/build-openstlinuxweston-stm32mp1-mx-sidacam/tmp-glibc/work/cortexa7t2hf-neon-vfpv4-ostl-linux-gnueabi/glib-2.0/1_2.62.6-r0/build/meson-logs/meson-log.txt
| ERROR: meson failed
| WARNING: exit code 1 from a shell command.
| ERROR: Execution of '/home/fpinilla/STM32MP15-Ecosystem-v3.0.0/Distribution-Package/build-openstlinuxweston-stm32mp1-mx-sidacam/tmp-glibc/work/cortexa7t2hf-neon-vfpv4-ostl-linux-gnueabi/glib-2.0/1_2.62.6-r0/temp/run.do_configure.294510' failed with exit code 1:
thanks for your help.
STM32MP15 Lines
2021-08-26 5:56 AM
Hi @FPini.1 ,
Did you install "Python3" on your station ?
Please refer to article https://wiki.st.com/stm32mpu/wiki/PC_prerequisites to check all requested package for Distribution support.
Olivier
2021-09-07 12:16 PM
I am hitting the exact same issue when I am compiling the STM32MP1's distro off https://github.com/STMicroelectronics/oe-manifest/tree/dunfell branch's manifest.
This is not a host PC installation issue rather a Yocto build system issue.
2021-09-08 12:03 AM
Hi @ZZhao.1 ,
What's you host station OS ?
Could you provide also what is printed out after execution of envsetup.sh ?
Olivier
2021-09-09 7:30 AM
I was trying to fix this problem by modifying the order of the layer in bblayers.conf file and it worked when I put the meta, meta-poky, and meta-oe at first, It didn't give me a compile error but in the end, it didn't generate me the uinitrd causing the openSTLinux couldn't boot correctly.
Thanks for your attention.
2021-11-10 4:36 AM
is there any solution about this issue?
I have the same error running on Ubuntu 20.04, running "bitbake -c populate_sdk st-image-weston" from openstlinux-5.10-dunfell-mp1-21-07-21 distro, with following configuration
DISTRO=openstlinux-weston MACHINE=stm32mp1
Thanks,
Michele
2021-11-19 5:20 AM
please cherry-pick this patch (from v3.1.0) on v3.0.2 version: https://github.com/STMicroelectronics/meta-st-stm32mp/commit/0099ab38118ed2735f0708b1080bb50d12955dfe
So "classes/python3native.bbclass" file has to be deleted
2021-12-01 11:11 PM
v3.0.3 delivered to correct this issue: https://github.com/STMicroelectronics/oe-manifest/tree/openstlinux-5.10-dunfell-mp1-21-11-30
But better take v3.1.0 if you can (latest ecosystem delivery).
Still investigations are ongoing to understand why the issue was not seen internally before the release (during validation tests).
