Power button doesn't trigger shutdown
  • January 23, 2024
  • 1405 views
I have an STM32MP1 MPU based module running OpenSTLinux.
Whenever I press the power button, this gets recorded in journalctl:
root@STLinux:~# journalctl --unit systemd-logind --follow
-- Logs begin at Fri 2020-02-07 15:50:56 UTC. --
Jan 22 15:15:37 STLinux systemd-logind[919]: Session c1 logged out. Waiting for processes to exit.
Jan 22 15:15:38 STLinux systemd[1]: Stopping Login Service...
Jan 22 15:15:38 STLinux systemd-logind[919]: Removed session c1.
Jan 22 15:15:38 STLinux systemd[1]: systemd-logind.service: Succeeded.
Jan 22 15:15:38 STLinux systemd[1]: Stopped Login Service.
-- Reboot --
Jan 22 15:15:45 STLinux systemd[1]: Starting Login Service...
Jan 22 15:15:48 STLinux systemd-logind[921]: Watching system buttons on /dev/input/event0 (pmic_onkey)
Jan 22 15:15:48 STLinux systemd-logind[921]: New seat seat0.
Jan 22 15:15:48 STLinux systemd[1]: Started Login Service.
Jan 22 15:15:56 STLinux systemd-logind[921]: New session c1 of user root.
Jan 23 07:05:00 STLinux systemd-logind[921]: Power key pressed.
Jan 23 07:05:02 STLinux systemd-logind[921]: Power key pressed.
Jan 23 07:05:05 STLinux systemd-logind[921]: Power key pressed.
Jan 23 07:05:07 STLinux systemd-logind[921]: Power key pressed.
But nothing else happens.
How can I make my system shut down when I press the power button?
This is /etc/systemd/logind.conf:
# This file is part of systemd.
# systemd is free software; you can redistribute it and/or modify it
# under the terms of the GNU Lesser General Public License as published by
# the Free Software Foundation; either version 2.1 of the License, or
# (at your option) any later version.
# Entries in this file show the compile time defaults.
# You can change settings by editing this file.
# Defaults can be restored by simply deleting this file.
# See logind.conf(5) for details.
[Login]
#NAutoVTs=6
#ReserveVT=6
#KillUserProcesses=yes
#KillOnlyUsers=
#KillExcludeUsers=root
#InhibitDelayMaxSec=5
HandlePowerKey=poweroff
HandleSuspendKey=suspend
#HandleHibernateKey=hibernate
#HandleLidSwitch=suspend
#HandleLidSwitchExternalPower=suspend
#HandleLidSwitchDocked=ignore
#PowerKeyIgnoreInhibited=no
#SuspendKeyIgnoreInhibited=no
#HibernateKeyIgnoreInhibited=no
#LidSwitchIgnoreInhibited=yes
#HoldoffTimeoutSec=30s
#IdleAction=ignore
#IdleActionSec=30min
#RuntimeDirectorySize=10%
#RemoveIPC=yes
#InhibitorsMax=8192
#SessionsMax=8192
Thanks.
Best answer by harm
I fixed this by installing acpid and creating a config file /etc/acpi/events/powerbtn containing:
event=button/power
action=/sbin/poweroff
(Restart acpid with systemctl restart acpid for the configuration to take effect.)
harmAuthor
I'm still stuck on this. If anyone needs more information, I'd be happy to provide this.
harmAuthorBest answer
event=button/power
