Trouble building meta-st-stm32mpu-app-logicanalyzer ("backend.c:49:10: fatal error: gtk/gtk.h: No such file or directory")
‎2020-02-18 8:38 AM
I need assistance building the https://github.com/STMicroelectronics/meta-st-stm32mpu-app-logicanalyser project. I have the Distribution-Package building successfully, but when I follow the instructions for the example meta layer, I get the following:
| #include <gtk/gtk.h>
| compilation terminated.
I’ve tried a manual “bitbake gtk+3�? to no avail. I’ve also tried uncommenting line 7 of https://github.com/STMicroelectronics/meta-st-stm32mpu-app-logicanalyser/blob/thud/recipes-graphics/st-software/logic-analyser-backend/Makefile.
- Labels:
Bug-report
STM32MP15 Lines
‎2020-03-02 4:59 AM
Indeed this works with 1.2.0, without modification from the git repo. Thank you.
‎2020-02-19 12:22 AM
Hi @JCant.1​
Thanks for reporting this.
Issue has been fix. You can refetch.
Sorry for inconvenience
BR,
Olivier
‎2020-02-19 5:28 AM
Thank you for getting back to me. What am I supposed to refetch? The repo at https://github.com/STMicroelectronics/meta-st-stm32mpu-app-logicanalyser hasn't been updated since Jan 9.
‎2020-02-19 6:17 AM
Indeed fix was not yet push
Should be ok now.
Don't be afraid with V1.2 compatibility ( next release coming soon), it might work with V1.1.0.
Olivier
‎2020-02-19 7:07 AM
When is V1.2 going to be released?
After pulling down a fresh clone of the logicanalyzer example, I get the following:
ERROR: Layer 'stm-st-stm32mp-app-logicanalyser' depends on layer 'stm-st-stm32mp-mx', but this layer is not enabled in your configuration
‎2020-02-19 7:29 AM
1.2.0 should be available by next Wednesday.
‎2020-02-19 7:31 AM
To fix issue of compilation, you can update the Makefile with:
# This Makefile is provided as an example of how to build a process that can
# communicate with a Storyboard application. It may require modifications in
# order to build on your host system. Please see ReadMe.html for a complete
# explanation
# Linux users add this
CFLAGS2 = -Wall $(shell pkg-config --cflags gtk+-3.0)
LDFLAGS2 = $(shell pkg-config --libs gtk+-3.0) -lpthread -lm -lc
LDFLAGS3 = -lpthread
all: backend keyboard
backend: backend.c
$(CC) $(CFLAGS) $(CFLAGS2) -o $@ $^ $(LDFLAGS) $(LDFLAGS2)
keyboard: keyboard.c
$(CC) $(CFLAGS) -o $@ $^ $(LDFLAGS) $(LDFLAGS3)
‎2020-02-19 8:17 AM
This is identical with the Makefile I've been using. I also just performed a "repo sync" in openstlinux-4.19-thud-mp1-19-10-09. Do I just need to wait until next Wed?
‎2020-02-19 9:08 AM
If you are sure of your Makefile, then yes, just wait for the 1.2.0
‎2020-03-02 4:59 AM
