2026-04-28 5:57 AM
I was checking if it is possible to test my M33 NS code I generated using CubeMX would work in Developer Mode. However, the information found on internet suggest it being difficult as it requires the clock to be configured by M33 and also needs RIF accesses making it difficult.
Without proper documentation on use case and how to use developer mode, it becomes challenging to work on a project within a stipulated time. So please, I would request for the help and Information to test and debug the code in Developer mode. Thanks for the support.
With regards
Amit
