STM32MP157C-DK2 - FDCAN not transmitting.
2020-04-09 12:41 AM
I'm using a ST32MP157C-DK2 board to develop an application running on CM4 that basically handles a CAN Standard communication.
I routed the FDCAN1 signals on PA11 and PA12 and I am trying to send out some random data with no result...
Here is my code:
static void MX_FDCAN1_Init(void)
/* USER CODE BEGIN FDCAN1_Init 0 */
/* USER CODE END FDCAN1_Init 0 */
/* USER CODE BEGIN FDCAN1_Init 1 */
/* USER CODE END FDCAN1_Init 1 */
hfdcan1.Instance = FDCAN1;
hfdcan1.Init.FrameFormat = FDCAN_FRAME_CLASSIC;
hfdcan1.Init.Mode = FDCAN_MODE_NORMAL;
hfdcan1.Init.AutoRetransmission = DISABLE;
hfdcan1.Init.TransmitPause = DISABLE;
hfdcan1.Init.ProtocolException = DISABLE;
hfdcan1.Init.NominalPrescaler = 1;
hfdcan1.Init.NominalSyncJumpWidth = 1;
hfdcan1.Init.NominalTimeSeg1 = 2;
hfdcan1.Init.NominalTimeSeg2 = 2;
hfdcan1.Init.DataPrescaler = 1;
hfdcan1.Init.DataSyncJumpWidth = 1;
hfdcan1.Init.DataTimeSeg1 = 1;
hfdcan1.Init.DataTimeSeg2 = 1;
hfdcan1.Init.MessageRAMOffset = 0;
hfdcan1.Init.StdFiltersNbr = 0;
hfdcan1.Init.ExtFiltersNbr = 0;
hfdcan1.Init.RxFifo0ElmtsNbr = 1;
hfdcan1.Init.RxFifo0ElmtSize = FDCAN_DATA_BYTES_8;
hfdcan1.Init.RxFifo1ElmtsNbr = 0;
hfdcan1.Init.RxFifo1ElmtSize = FDCAN_DATA_BYTES_8;
hfdcan1.Init.RxBuffersNbr = 0;
hfdcan1.Init.RxBufferSize = FDCAN_DATA_BYTES_8;
hfdcan1.Init.TxEventsNbr = 1;
hfdcan1.Init.TxBuffersNbr = 8;
hfdcan1.Init.TxFifoQueueElmtsNbr = 8;
hfdcan1.Init.TxFifoQueueMode = FDCAN_TX_FIFO_OPERATION;
hfdcan1.Init.TxElmtSize = FDCAN_DATA_BYTES_8;
if (HAL_FDCAN_Init(&hfdcan1) != HAL_OK)
Error_Handler();
/* USER CODE BEGIN FDCAN1_Init 2 */
/* USER CODE END FDCAN1_Init 2 */
int main(void)
/* USER CODE BEGIN 1 */
uint32_t Tickstart;
/* USER CODE END 1 */
HAL_Init();
/* USER CODE BEGIN Init */
/* USER CODE END Init */
if(IS_ENGINEERING_BOOT_MODE())
SystemClock_Config();
/* Configure the peripherals common clocks */
PeriphCommonClock_Config();
/* IPCC initialisation */
MX_IPCC_Init();
/* OpenAmp initialisation ---------------------------------*/
MX_OPENAMP_Init(RPMSG_REMOTE, NULL);
/* USER CODE BEGIN SysInit */
/* USER CODE END SysInit */
MX_GPIO_Init();
MX_FDCAN1_Init();
/* USER CODE BEGIN 2 */
/*##-2 Start FDCAN controller (continuous listening CAN bus) ##############*/
if (HAL_FDCAN_Start(&hfdcan1) != HAL_OK)
Error_Handler();
/*##-3 Transmit messages ##################################################*/
/* Add message to Tx FIFO */
TxHeader.Identifier = 0x444;
TxHeader.IdType = FDCAN_STANDARD_ID;
TxHeader.TxFrameType = FDCAN_DATA_FRAME;
TxHeader.DataLength = FDCAN_DLC_BYTES_8;
TxHeader.ErrorStateIndicator = FDCAN_ESI_ACTIVE;
TxHeader.BitRateSwitch = FDCAN_BRS_OFF;
TxHeader.FDFormat = FDCAN_CLASSIC_CAN;
TxHeader.TxEventFifoControl = FDCAN_NO_TX_EVENTS;
TxHeader.MessageMarker = 0;
if (HAL_FDCAN_AddMessageToTxFifoQ(&hfdcan1, &TxHeader, TxData0) != HAL_OK)
Error_Handler();
/* Get tick */
Tickstart = HAL_GetTick();
/* Check transmission occurred before timeout */
while(HAL_FDCAN_IsTxBufferMessagePending(&hfdcan1, FDCAN_TX_BUFFER0 ) != 0)
if((HAL_GetTick() - Tickstart) > TX_FAST_TIMEOUT)
Error_Handler();
break;
/* USER CODE END 2 */
/* Infinite loop */
/* USER CODE BEGIN WHILE */
while (1)
HAL_Delay(100);
/* USER CODE END WHILE */
/* USER CODE BEGIN 3 */
/* USER CODE END 3 */
void HAL_FDCAN_MspInit(FDCAN_HandleTypeDef* hfdcan)
RCC_PeriphCLKInitTypeDef PeriphClkInit = {0};
if(hfdcan->Instance==FDCAN1)
/* USER CODE BEGIN FDCAN1_MspInit 0 */
/* USER CODE END FDCAN1_MspInit 0 */
/** Initializes the peripherals clock
PeriphClkInit.PeriphClockSelection = RCC_PERIPHCLK_FDCAN;
PeriphClkInit.FdcanClockSelection = RCC_FDCANCLKSOURCE_HSE;
if (HAL_RCCEx_PeriphCLKConfig(&PeriphClkInit) != HAL_OK)
Error_Handler();
/* Peripheral clock enable */
__HAL_RCC_FDCAN_CLK_ENABLE();
__HAL_RCC_GPIOA_CLK_ENABLE();
/**FDCAN1 GPIO Configuration
PA11 ------> FDCAN1_RX
PA12 ------> FDCAN1_TX
GPIO_InitStruct.Pin = GPIO_PIN_11;
GPIO_InitStruct.Mode = GPIO_MODE_AF;
GPIO_InitStruct.Alternate = GPIO_AF9_FDCAN1;
GPIO_InitStruct.Pin = GPIO_PIN_12;
/* USER CODE BEGIN FDCAN1_MspInit 1 */
/* USER CODE END FDCAN1_MspInit 1 */
Any idea? What am I doing wrong?
Thank you!
Andrea
2020-04-09 8:44 AM
Hi @AComa.170
Are you in Engineering boot mode or Production mode.
If second case did you properly manage assignement of FDCAN in Device Tree ?
Also I notice a long thread about FDCAN here in case it contains hint for you :
https://community.st.com/s/question/0D50X0000C9fliSSQQ/stm32mp1-fdcan-issues
Hope it help
Olivier
2020-04-10 12:02 AM
Hi @Community member,
I'm in production mode... Am I supposed to assign FDCAN in Device Tree even if I'm using it on Cortex-M4? If yes, is there a guide about this?
Thank you so much!
Andrea
2020-04-10 2:28 AM
Hi @AComa.170
Yes, you must have some Device Tree related declaration, as shared resources (e.g. clocks) are handled by Linux.
Please have a look to https://wiki.st.com/stm32mpu/wiki/How_to_assign_an_internal_peripheral_to_a_runtime_context
2020-04-10 5:26 AM
Hi @PatrickF ,
thank you for the informations, now thigs are getting clearer.
I switched to Engineering Mode, but still no data on FDCAN output port...
Andrea
2020-04-10 5:49 AM
Please check first SystemClock_Config() and PeriphCommonClock_Config().
I see you are using HSE for FDCAN, so check if HSE is started. Similarly, check correct PLL and all clocks related settings.
is the FDCAN correctly initialized in MX_FDCAN1_Init() ?
Then, you need to debug step by step to see what is blocking. I'm not specialist of FDCAN, so I cannot check if your functions usage are ok.
2020-04-15 1:44 AM
Hello everyone,
I checked what @PatrickF has suggested, everyting seems to be ok.
I found out that the only way to see something on the TX pin is setting the peripheral on EXTERNAL_LOOPBACK_MODE...
Obviously, in this way I'm not able to receive anything from external devices...
Is there something in particular that may cause this condition?
2023-02-01 7:07 AM
@AComa.170
@PatrickF
Hi guys, I have the same issue here, I'm trying to use fdcan in m4, and i upload an new device tree which is generated by stm32cudeide, However nothing to seem to work, even though it's working in engineering mode.
what do you think is the problem?
I notice the clock is not enabled when I'm looking to clock summary
