Kernel Config/ Adding applications/ Building Images
‎2020-12-08 5:22 AM
Hello
I have a question concerning how to build a customized image.
I followed this link first to get a general Idea
After that, I found that if I need to customize my Kernel and choose my packages (Customer apps) I can follow these links: Customer App and Kernel config
1- Should I customize before building my image using "bitbake <image>"
or after (I suppose before but just asking)
Just to be clear I will give some examples:
- Customer app will be used to add packages that may not be present
- Kernel configurations: To activate modules and features for example security, Bluetooth and Wi-Fi features.
2- In which file do I need to be in order to apply the modifications that I want in my final image that I will flash.
Best regards
OpenSTLinux
STM32MP15 Lines
‎2020-12-08 6:23 AM
Hi @SigmaPrime​ ,
Prior to engage with Distribution package, are you sure you really need it ?
What do you want to do ?
Did you read this ?
https://wiki.st.com/stm32mpu/wiki/Which_STM32MPU_Embedded_Software_Package_better_suits_your_needs
Olivier
‎2020-12-08 6:37 AM
Well Basically I am working on an IoT Project.
The First step is to learn how to set up my Linux image (Kernel Configuration and Package customization).
This means that I have to build an image where all the tools libs packages drivers and modules are available.
‎2021-01-20 8:40 AM
Hi @SigmaPrime​ ,
Did you finally find what you were looking for ?
If a comment answer your question, please close this topic by choosing Select as Best. This will help other users to find that answer faster.
Thanks for you participation in this community !
Olivier
