How to assgin TIM1 as time base source on cube MX for STM32MP157C-DK2
2020-01-30 7:59 AM
I wish use FreeRTOS with STM32MP157C. When I configure my bord on CubeMX a message pop up says I should configure SYS parameter with an others time source than sysTick. But if I configure TIM1 for example I cannot assign TIM1 in SYS section .
card
Have you any ideas to solve this problem ?
Best Regards,
Arnaud Bousquet
FreeRTOS
STM32CubeMX
STM32MP15 Lines
TIM
2020-01-30 9:07 AM
Hi @ABous.1
Normally you just have to assign TIM1 on M4 context without enabling anything else.
Then TIM1 should be available in SYS section.
Hope it help
Olivier
2020-01-31 2:45 AM
I try again with your recommendation but without success.
I do some screenshot of my modification in cubeMX project.
PS: My STMcubeMX version is 5.5.0.
Best regards,
Arnaud Bousquet
2020-01-31 6:09 AM
Hi @ABous.1
You have to remove Clock Source setting in TIM1. Set it back to Disable.
Olivier
