Where do I find the .IOC file for STM32WB cable replacement example?
JBakk.2
Imen.D
Hello @Community member​ and welcome to the STM32 Community :)
For BLE_CableReplacement example, there is no .ioc file provided within STM32CubeWB.
You will find in this AN5155 the list of STM32CubeMX-generated examples (ioc files) provided with STM32CubeWB firmware examples.
There is a ready BLE_CableReplacement project with STM32CubeWB for different toolchains (EWARM, MDK-ARM, STM32CubeIDE):
STM32Cube_FW_WB_V1.11.0\Projects\P-NUCLEO-WB55.Nucleo\Applications\BLE\BLE_CableReplacement
In this STM32WB Workshop, you will find a Hands-on that helps you to run this example.
Imen
Imen
JBakk.2
Hello Imen
Thanks for your answer. I have the Cable replacement up running, but I want to use this as a startup for a project where I will use a NFC reader and several motion detectors. Will it be possible to make a .ioc that will work with the cable replacement?
Jan-Petter
ICMosquera
+1 on this request. But seems no answer from the development team. What a let down
