UART data not matching
Ranjeet Singh
data on serial  monitor
tera term setting
what is the reason of data mis matching ?
10 REPLIES 10
How exact are you wiring this? Using the ST-LINK VCP, or an external dongle or converter?
The pin outputs are at CMOS level, not compatible with RS232 levels/connectivity.
Send a 0x55 pattern repeatedly, check signal with a scope, confirm baud rate, ie 4800 Hz squarewave is 9600 baud.
