Time Server Module is doing Malfunctioning after POR through USB cable removal.
Hi Team,
We are using the TIME Server Module for our Generic timer's purpose, when we freshly loaded the Hex file, it is working fine as expected.
Whenever if we did the Power on Reset through for the Evalution board the Timer Server is malfunctioning. It is giving the Wrong values. Eg: If we configure the Timer server for 1min, we are getting the Callback function properly., after doing the POR same timer is calling for 5sec.
Could anyone help me out on this issue. As part of the POR, we need to do any other things, means Clock Settings Or RCC Settings after POR through USB cable Removal.
Douglas MILLER
This forum thread was marked by the moderator as needing a little more investigation, so a Support case was created in your name and will be handled off-line. Should anyone have any similar questions, please feel free to open a Support case directly at your myST portal: https://st.com/ols
