STM32WL5MOCH6S battery voltage reading
Trace_LEMS
We have developed wireless temperature sensor using STM32WL5MOCH6S module , it is fully battery operated device and Battery is connected directly to supply  pin of the module, in this we would want to the read battery voltage , is there any register or command available for reading supply pin to read the battery voltage or any other method to read the battery voltage?
Kindly help us in this matter.
Andrew Neil
Have you checked the Datasheet and the Reference Manual - they would show you what options the ADC has for its input/source to measure ...
