Stm32wb55 clock settings
‎2019-05-28 1:54 PM
I created a simple BLE peripheral project by CubeMX with the clock setting below.
HSE=32 PLL M=2 N=16 R=8 SYSCLK=32M system clock mux=PLLCLK
Everything looks right and even the BLE sniffer receives the advertisement broadcast. However, the cellphone cannot discover the BLE device.
Accidentally, i changed the "system clock mux" to HSE from PLL. and the problem resolved. and the problem re-appears after changing back the clock setting. I'm wondering why the PLL clock cannot work eve it has same frequency as HSE. is there any restriction on ble clock?
attached the clock initialization code.
RCC_PeriphCLKInitTypeDef PeriphClkInitStruct = {0};
/** Configure LSE Drive Capability
__HAL_RCC_LSEDRIVE_CONFIG(RCC_LSEDRIVE_LOW);
__HAL_PWR_VOLTAGESCALING_CONFIG(PWR_REGULATOR_VOLTAGE_SCALE1);
/** Initializes the CPU, AHB and APB busses clocks
RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSI|RCC_OSCILLATORTYPE_LSI1
|RCC_OSCILLATORTYPE_HSE|RCC_OSCILLATORTYPE_LSE;
RCC_OscInitStruct.LSEState = RCC_LSE_ON;
RCC_OscInitStruct.LSIState = RCC_LSI_ON;
RCC_OscInitStruct.PLL.PLLM = RCC_PLLM_DIV2;
RCC_OscInitStruct.PLL.PLLN = 16;
RCC_OscInitStruct.PLL.PLLR = RCC_PLLR_DIV8;
RCC_OscInitStruct.PLL.PLLQ = RCC_PLLQ_DIV2;
Error_Handler();
/** Configure the SYSCLKSource, HCLK, PCLK1 and PCLK2 clocks dividers
RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK4|RCC_CLOCKTYPE_HCLK2
|RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
RCC_ClkInitStruct.AHBCLK2Divider = RCC_SYSCLK_DIV1;
RCC_ClkInitStruct.AHBCLK4Divider = RCC_SYSCLK_DIV1;
if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_1) != HAL_OK)
Error_Handler();
/** Initializes the peripherals clocks
PeriphClkInitStruct.PeriphClockSelection = RCC_PERIPHCLK_SMPS|RCC_PERIPHCLK_RFWAKEUP
|RCC_PERIPHCLK_RTC|RCC_PERIPHCLK_USART1;
PeriphClkInitStruct.Usart1ClockSelection = RCC_USART1CLKSOURCE_PCLK2;
PeriphClkInitStruct.RTCClockSelection = RCC_RTCCLKSOURCE_LSI;
PeriphClkInitStruct.RFWakeUpClockSelection = RCC_RFWKPCLKSOURCE_LSE;
PeriphClkInitStruct.SmpsClockSelection = RCC_SMPSCLKSOURCE_HSE;
PeriphClkInitStruct.SmpsDivSelection = RCC_SMPSCLKDIV_RANGE0;
if (HAL_RCCEx_PeriphCLKConfig(&PeriphClkInitStruct) != HAL_OK)
Error_Handler();
- Labels:
RCC
STM32WB series
‎2019-10-17 8:02 PM
I've just run into the exact same thing although I was trying to run the M4 at 64 MHz. Even changing the PLL down to 32 MHz the BLE connection is unstable. Ideas?
‎2020-02-27 6:23 AM
The solution is that if the PLL is used the frequency must be trimmed. You can follow the code from X-CUBE-CLKTRIM to fine tune it.
