STM32WB FUS upgrade fail from 1.1.0 to 1.1.2
2021-03-10 11:29 PM
Please, Help me.
Attach log:
PS C:\> STM32_Programmer_CLI.exe -c port=usb1 -fwdelete
STM32CubeProgrammer v2.6.0
USB speed : Full Speed (12MBit/s)
Manuf. ID : STMicroelectronics
Product ID : DFU in FS Mode
SN : 20583172544E
FW version : 0x011a
Device ID : 0x0495
Device name : STM32WBxx
Flash size : 1 MBytes
Device type : MCU
Device CPU : Cortex-M4
FUS state is FUS_ERROR
FUS status is FUS_NOT_RUNNING
FUS state is FUS_IDLE
FUS status is FUS_NO_ERROR
Deleting firmware ...
Firmware delete finished
- Labels:
STM32CubeProgrammer
STM32WB series
2021-03-11 8:33 AM
FUS V1.1.2 is an intermediate version dedicated for optimization of flash usage and some internal security enhancements.
It doesn’t contain any major changes and so there is no need for a customer to move to V1.1.2.
It may even be considered as being the same version as the current one installed.
Hence the message you get: older/equal to the FUS version already installed !
2021-03-10 11:30 PM
PS C:\> STM32_Programmer_CLI.exe -c port=usb1 -r32 0x20030030 1
SN : 20583172544E
FW version : 0x011a
Device ID : 0x0495
Device type : MCU
100%e CPU : Cortex-M4
Reading 32-bit memory content
Address: : 0x20030030
0x20030030 : 01010000
2021-03-10 11:30 PM
PS C:\> STM32_Programmer_CLI.exe -c port=usb1 -fwupgrade C:\STM32Cube\Repository\STM32Cube_FW_WB_V1.11.0\Projects\STM32WB_Copro_Wireless_Binaries\STM32WB5x\stm32wb5x_FUS_fw.bin 0x080EC000 firstinstall=0
SN : 20583172544E
FW version : 0x011a
Device ID : 0x0495
Device type : MCU
栢栢栢栢栢栢栢栢栢栢栢栢栢栢栢栢栢栢栢栢栢栢栢栢栢Current FUS Version : 0x01010000
Uploaded FUS Version : 0x01010200
FUS state is FUS_SERVICE_ONGOING
FUS status is FUS_IMAGE_NOT_FOUND
Old wireless stack delete ...
Download firmware image at address 0x80ec000 ...
Memory Programming ...
Opening and parsing file: stm32wb5x_FUS_fw.bin
File : stm32wb5x_FUS_fw.bin
Address : 0x080EC000
Erasing internal memory sectors [236 241]
erasing sector 0236 @: 0x080ec000 done
erasing sector 0237 @: 0x080ed000 done
erasing sector 0238 @: 0x080ee000 done
erasing sector 0239 @: 0x080ef000 done
erasing sector 0240 @: 0x080f0000 done
erasing sector 0241 @: 0x080f1000 done
Download in Progress:
栢栢栢栢栢栢栢栢栢栢栢栢栢栢栢栢栢栢栢栢栢栢栢栢굇?100%%
File download complete
Time elapsed during download operation: 00:00:00.594
Firmware Upgrade process started ...
Updating firmware ...
Waiting for firmware upgrade end
FUS state is WIRELESS_STACK_UPGRADE_ONGOING
FUS status is FUS_FW_ROLLBACK_ERROR
Error: The FUS version you're trying to install is older/equal to the FUS version already installed !
2021-03-10 11:30 PM
PS C:\> STM32_Programmer_CLI.exe -c port=usb1 -ob displ
SN : 20583172544E
FW version : 0x011a
Device ID : 0x0495
Device type : MCU
UPLOADING OPTION BYTES DATA ...
Bank : 0x00
Address : 0x1fff8000
栢栢栢栢栢栢栢栢栢栢栢栢栢栢栢栢栢栢栢栢栢栢栢栢栢 100%
OPTION BYTES BANK: 0
Read Out Protection:
RDP : 0xAA (Level 0, no protection)
BOR Level:
BOR_LEV : 0x0 (BOR Level 0 reset level threshold is around 1.7 V)
User Configuration:
nBOOT0 : 0x1 (nBOOT0=1 Boot from main Flash)
nBOOT1 : 0x1 (Boot from Flash if nBoot0=0 otherwise system memory)
nSWBOOT0 : 0x1 (BOOT0 taken from PH3/BOOT0 pin)
SRAM2RST : 0x0 (SRAM2 erased when a system reset occurs)
SRAM2PE : 0x1 (SRAM2 parity check disable)
nRST_STOP : 0x1 (No reset generated when entering the Stop mode)
nRST_STDBY : 0x1 (No reset generated when entering the Standby mode)
nRSTSHDW : 0x1 (No reset generated when entering the Shutdown mode)
WWDGSW : 0x1 (Software window watchdog)
IWGDSTDBY : 0x1 (Independent watchdog counter running in Standby mode)
IWDGSTOP : 0x1 (Independent watchdog counter running in Stop mode)
IWDGSW : 0x1 (Software independent watchdog)
IPCCDBA : 0x0 (0x0)
Security Configuration Option bytes:
ESE : 0x1 (Security enabled)
SFSA : 0xF4 (0xF4)
FSD : 0x0 (System and Flash secure)
DDS : 0x1 (CPU2 debug access disabled)
C2OPT : 0x1 (SBRV will address Flash)
NBRSD : 0x0 (SRAM2b is secure)
SNBRSA : 0x10 (0x10)
BRSD : 0x1 (SRAM2a is non-secure)
SBRSA : 0x0 (0x0)
SBRV : 0x3D000 (0x3D000)
PCROP Protection:
PCROP1A_STRT : 0x1FF (0x80FF800)
PCROP1A_END : 0x0 (0x8000800)
PCROP_RDP : 0x0 (PCROP zone is kept when RDP is decreased)
PCROP1B_STRT : 0x1FF (0x80FF800)
PCROP1B_END : 0x0 (0x8000800)
Write Protection:
WRP1A_STRT : 0xFF (0x80FF000)
WRP1A_END : 0x0 (0x8000000)
WRP1B_STRT : 0xFF (0x80FF000)
WRP1B_END : 0x0 (0x8000000)
2021-03-11 8:33 AM
