Program usb dongle board from P-Nucleo-WB55 pack using st-link on included Nucleo68 board
CWill.4
I am trying to use a ble application on the dongle board included in the P-Nucleo-WB55 pack. Is it possible to use the st-link debugger found on the Nucleo68 board to program the dongle? (This is the other board found in the P-Nucleo pack) the other alternative would be buying an external st-link programmer, something I’d like to avoid. I tried connecting the nrst, gnd, swdio, and swclk pins from cn13 on the Nucleo68 to the dongle and powering both boards, but stm32cubeprogrammer did not recognize the stm32 device.
Houda GHABRI
Hi @CWill.4​ ,
The dongle board is designed to be programmed with Bootloader using USB interface.
Hope this helps you,
Houda
Houda GHABRI
Hi @CWill.4​ ,
Houda
