P-NUCLEO-LRWAN Antenna
DarioS
Hello i am looking for specifications for the antennas supplied with the p-nucleo-lrwan packages. Unfortunately i cannot find any specific information about the supplied antennas such as impedance, gain, etc in the documentation of the products. I would appreciate any help.
Oh, I got it.
you can buy it from local with regular antenna (normally 50Ohm) in band that you use with Male SMA Connector.
Tinnagit
Senior II
It's regular Male SMA connector type but you have to select the frequency band.
And if you want to new design with chip that I recommend you to do follow design guideline document.
Hello Tinnagit, thank you for your reply. I would like to test a new concentrator, but it was delivered without an antenna. Now i was wondering if i can safely take the antenna out of the p-nucleo kit to test the new concentrator. But since i have no information about the impedance, i am afraid that i might damage the new concentrator.
Oh, I got it.
