2026-04-11 4:46 AM - last edited on 2026-04-13 2:12 AM by Andrew Neil
Hello ST team,
I am using a P-NUCLEO-LRWAN3 starter kit with the NUCLEO-F746ZG gateway board.
I accidentally overwrote the original gateway firmware on the F746ZG. I have already recovered the board so that it can be connected and programmed again with STM32CubeProgrammer, but I no longer have the original gateway firmware binary.
I tried flashing another gateway binary:
st-nucleo-lora-gw-at-fw-v2.1.7-eu868-TTN.bin
The firmware runs, but it is clearly not the correct one for my hardware. After flashing it, the serial output shows EU868 / TTN settings and reports:
Before I overwrote the original firmware, the gateway output was different. The original serial output showed:
So I believe the original firmware for my board was a 470 MHz / CN470 / LORIOT-related gateway firmware, not the EU868 TTN version.
Could you please help provide the correct original gateway firmware binary for my hardware?
My information:
The board itself is working now:
I only need the correct original gateway firmware binary for this kit and band.
Thank you very much for your help.
Best regards,
lyf
2026-04-14 3:59 AM
Hi @leeyef,
Glad to know that you have the firmware from our ST local team.
Please allow me to close this thread and thank you for your contribution.
2026-04-13 2:06 AM
Note that the P-NUCLEO-LRWAN3 gateway is obsolete:
Even if you did manage to find the original firmware, LoRaWAN specs have moved on since then.
Note also that this gateway has never been recommended for deployment.
2026-04-13 2:22 AM
Yes, I know the P-NUCLEO-LRWAN3 gateway is obsolete. But I am currently working on my undergraduate graduation project based on it (I don't know why my professor chose this pack, perhaps only for laboratory use), and there's no time to change to another packs. I just want to know how to contact with ST to get the firmware and finish my project.
2026-04-13 2:26 AM
As mentioned in the linked post, the firmware comes from RisingHF (the module manufacturer) - not ST.
@leeyef wrote:my professor chose this pack
You need to flag this to your professor!
2026-04-13 2:40 AM
:face_with_tears_of_joy::face_with_tears_of_joy:ok, thank you a lot for your time.
2026-04-14 3:59 AM
Hi @leeyef,
