No file/directory on example
‎2025-01-27 3:30 PM
I get this error when trying to using the BLE_heartrate example for the nucleo-WB09KE. I have uninstalled and reinstalled the IDE.
STM32WB0 series
‎2025-01-28 12:02 AM - edited ‎2025-03-06 5:19 AM
This is a Known limitation on CubeMX when using the example selector, you can find it with the workaround on STM32CubeMX errata 6.13.x - stm32mcu.
Update (24W10): I've tested this problem with the STM32CubeMX V6.14.0, STM32CubeIDE V1.18.0 and the STM32CubeWB0 V1.2.0. Even generation issue detected with the Example selector is solved.
Best Regards.
STTwo-32
‎2025-01-27 5:09 PM
So probably not that then..
Determine WHERE the file is within to project tree, or WB0 library and CMSIS include directories.
Make sure that the "include paths"point a where the file can be found.
‎2025-01-27 7:34 PM
After importing the example project, it turns out that project is missing a lot of files.
When trying to find the osal.h file, I found the osal.c file in the Modules folder but you can see it has a broken link icon along with other files.
When looking at the Modules directory in File Explorer, there is not one single c/h file in the root directory nor the other 6 folders.
TimerCallback tutorial! | UART and DMA Idle tutorial!
‎2025-01-27 10:50 PM
Hello @Chris5 and welcome to the ST Community.
I've personally test it using the STM32CubeWB0 V1.1.0, STM32CubeIDE V1.17.0 and it works fine for me:
Could you please try to import it using the following Methode:
Go to File > Open Projects from File System... > and select the directory of your project. After that, on the Folder file "Repository\STM32CubeWB0\Projects\NUCLEO-WB09KE\Applications\BLE\BLE_HeartRate" select the STM32CubeIDE folder.
Best Regards.
STTwo-32
‎2025-01-27 11:16 PM
Try to Import it from the example selector. The files are missing as i had indicated from earlier in STM32CubeIDE 1.7.0 and I just tried it in 1.16.1 and the same thing, files are missing.
Best Regards.
STTwo-32
