Issue not receiving in RX2 with I-CUBE-LRWAN and Nucleo-L152RE
Options
‎2016-10-01 2:32 AM
Posted on October 01, 2016 at 11:32
#i-cube-lrwan
We started development of a LoRaWAN Sensor with the I-CUBE-LRWAN software stack in combination with a NUCLEO-L152RE and SX1272MB2DAS expansion board.I have made the following changes to the code after a clean download:- Changed commissioning.h file to do ADP with my Lorank8 gateway - Disabled dutycycle in lora.c:81 - Enabled LORAWAN_CONFIRMED_MSGNo what I expect from the code is to receive the confirm message send from the gateway in RX2. I checked with a IMST LoRaWAN node to check if the downlink message is actually send by the gateway but this node receives the downlink confirm message in RX2 without problem (This node uses a STM32L1CB MCU and runes this software: https://github.com/Lora-net/LoRaMac-node). But the issue is the almost unchanged I-CUBE-LRWAN software doesn�t receive anything in RX2. It does receive in RX1 fine. My guess is it has something to do with the L152RE MCU type.I use Keil to compile and flash the software.See my Loriot.io log below. As you can see the Node doesn�t receive the ACK and will retransmit for 8 times and then continue to the next sequence number. Thanks in advance!MichaelSoftware used:http://www.st.com/content/st_com/en/products/embedded-software/mcus-embedded-software/stm32-embedded-software/stm32cube-expansion-software/i-cube-lrwan.html
Labels:
LoRa
Options
‎2016-10-01 3:35 AM
Posted on October 01, 2016 at 12:35
Looks like we solved it by changing the bitrate for RX2 to the right one.
Options
‎2016-11-17 8:03 AM
Posted on November 17, 2016 at 17:03
Hi devid.michael.001,
I have the same problem working with STM32L152RE in RX2. could you give me more information to solve this problem? Thanks in advance
