I Cube LrWan Bug on CalculateBackOff (on Join procedure)
Fabien LETORT
Posted on April 27, 2017 at 11:23
The CalculateBackOff method of teh i cuve lrwan is too old and contains a major bug for join duty cycle procedure.
The calcBackOff
ElapsedTime is always now !.
In case of a new Initiliazation of the LoRa Stack, maybe 10 hours after the RTC startup, the join procedure will be delayed. This elapsed time must be the the
LoRaMacInitializationTime as made in the official semtech repo, see following diff....
https://github.com/Lora-net/LoRaMac-node/commit/ab4a779cc4f159d39b4b0409bd7392d3e4d2cf7b
https://github.com/Lora-net/LoRaMac-node/commit/f8ad47e4b73370ee1e977866fa1946f274a362aa
In is really a mess that your fork of the semtech official repo is not on github to can update easily all correction made on the official repo.
#i-cube-lrwan
5 REPLIES 5
Amel NASRI
Posted on May 05, 2017 at 11:55
Hello
LETORT.Fabien
Please note that your feedback & proposal are reported internally for farther check. I will keep you informed if I get more details on this regard.
-Amel
Amel NASRI
Posted on May 05, 2017 at 17:35
Hello
LETORT.Fabien
As already asked in
https://community.st.com/0D50X00009XkXv1SAF
, could you please provide following details:
  • which I-CUBE-LRWAN version are you using?
  • what is exactly the example you tested (to reproduce the issue)?
  • As HW, is it theP-NUCLEO-LRWAN1?
-Amel
Amel NASRI
Posted on May 16, 2017 at 11:00
Hello
LETORT.Fabien
Please note that a new version of I-CUBE-LRWAN is planned to be available soon in order to support latest fixes from GitHub on the Mac.
-Amel
Posted on May 20, 2017 at 09:01
Just to add that Fabien's point '
In is really a mess that your fork of the semtech official repo is not on github to can update easily all correction made on the official repo.' in my view has much merit.  Although this presumably would require a significant shift in STM's approach to making software available.
Amel NASRI
Posted on June 11, 2018 at 10:50
Please note that a version
http://www.st.com/content/st_com/en/products/embedded-software/mcus-embedded-software/stm32-embedded-software/stm32cube-expansion-packages/i-cube-lrwan.html
of I-CUBE-LRWAN is available on the web and should be fixing some issues reported here as well as others.
-Amel
