Help with SystemClock_Config
GS2
Senior II
How to combine settings in SystemClock_Config to use both keyboard and ADC examples?
In keyboard project there is the follow setting in SystemClock_Config:
RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_MSI;
RCC_OscInitStruct.MSIState = RCC_MSI_ON;
RCC_OscInitStruct.MSICalibrationValue = RCC_MSICALIBRATION_DEFAULT;
RCC_OscInitStruct.MSIClockRange = RCC_MSIRANGE_6;
RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_MSI;
RCC_OscInitStruct.PLL.PLLM = RCC_PLLM_DIV1;
RCC_OscInitStruct.PLL.PLLN = 32;
RCC_OscInitStruct.PLL.PLLP = RCC_PLLP_DIV5;
RCC_OscInitStruct.PLL.PLLR = RCC_PLLR_DIV2;
RCC_OscInitStruct.PLL.PLLQ = RCC_PLLQ_DIV4;
In ADC sample:
RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSI48|RCC_OSCILLATORTYPE_HSI
|RCC_OSCILLATORTYPE_HSE|RCC_OSCILLATORTYPE_LSE;
RCC_OscInitStruct.LSEState = RCC_LSE_ON;
RCC_OscInitStruct.HSI48State = RCC_HSI48_ON;
8 REPLIES 8
KnarfB
There are so many examples and versions, it would be helpful if you gave as many details as possible, e.g. by referring to https://github.com/STMicroelectronics/STM32CubeWB/tree/master
There is no combination, it is "either or". And the 2nd settings make little sense to me as they activate several competing clocks (HSI/HSE/HSI48).
hth
KnarfB
GS2
Senior II
Thank you for response.
The first project is - https://github.com/stm32-hotspot/STM32WB-BLE-HID-Selfie/blob/164a8d2e9745f3a159ba92a056bd01e4a384f72a/Projects/P-NUCLEO-WB55.Nucleo/Applications/BLE/BLE_Hid_Selfie
The second project I am trying to use for ADC is - C:\Users\USER\STM32Cube\Repository\STM32Cube_FW_WB_V1.20.0\Projects\P-NUCLEO-WB55.Nucleo\Examples\ADC\ADC_SingleConversion_TriggerSW_IT
Hello @GS2 ,
Please kindly use </> button to share a code. Refer to this post. I'm editing your post.
Thank you for your understanding.
GS2
Senior II
Thank you. I will try.
What about:
|RCC_OSCILLATORTYPE_HSE|RCC_OSCILLATORTYPE_MSI;
Pavel A.
Usually to understand the clock settings, the Clocks view of CubeMX is very helpful (besides reading the fine RM).
On this view you see the clock sources and frequencies of relevant modules.
So, decide which OSC  you want to have in the merged project (usually HSE with PLL),  then tweak the controls so that these frequencies remain same.  Click "Generate code".
GS2
Senior II
Hello @GS2 ,
Could you please state on this case.
If your question has been answered please accept as solution the comment that provided it or tell how you solved you issue and accept it as solution.
Thank you
