Client writing a value to GATT write attribute
‎2023-01-19 10:36 PM
can someone help me with how to write a value to the server from the client? which API to use
Thank you,
STM32WB series
‎2023-01-20 12:58 AM
Hello @Community member​
Could you please precise the STM32 product you are using? STM32WB ..? Which type of server? Do you mean using host stack subsystem of Bluetooth? If so, I suggest to refer to STM32 Bluetooth Low Energy - stm32mcu
‎2023-01-20 2:58 AM
STM32WB55CU6 custom board as client and ESP32 as server, Connection between client and server done, Now i need to write a value to server from client
‎2023-01-20 2:59 AM
I am using GAP connection and GATT attribute method
‎2023-01-20 3:11 AM
You can refer to AN5289, section 6 Step by step design of a BLE application. Table 6. to choose the API
‎2023-01-20 3:27 AM
Thank you,
I have followed this document to establish a connection, but in the document, I didn't understand how to write attribute value to the server from the client
‎2023-01-23 10:15 AM
To write a value from your client to your server, in case of write without response you can use ACI_GATT_WRITE_WITHOUT_RESP command and in case of write with response you can use ACI_GATT_WRITE_CHAR_VALUE command. You can look BLE_p2pServer/BLE_p2pClient examples which allow to establish a connection and exchange information between two STM32WB boards.
Best Regards
