B-L072Z-LRWAN1 Current Consumption
S.M.
I am using B-L072Z-LRWAN1 and AT_Slave project from I-Cube-LRWAN. Can Anyone help me with the setup to measure current consumption like jumper position and across which pins to measure current?
Thank You
Clive1 (HNL)
Senior II
The manual describes JP1, JP2 and JP3 and the related solder bridges SB19, SB14 and SB17, start with those perhaps?
https://www.st.com/content/ccc/resource/technical/document/user_manual/group0/ac/62/15/c7/60/ac/4e/9c/DM00329995/files/DM00329995.pdf/jcr:content/translations/en.DM00329995.pdf
I think @Andrew Neil​ identified a couple of components in the battery path that could be removed also.
