2024-04-18 12:10 PM
For a project im working on i need to be able to record sound with a battery powered microcontroller and send it to an RPi. I saw that the STM32WB was capable of this but can anyone tell me if i will be able to receive and process the audio file on the RPi since it only has BLE 5.0 and not 5.4 like the microcontroller.
thanks in advance
2024-05-29 04:35 AM
Hello @Jt1002
BLE is designed to be backward compatible, so a device with BLE 5.0 should be able to communicate with a device that supports newer versions. For the processing on the Receive board, I can't confirm anything since is not our product. I suggest you ask the owner of the receive node about that.
Best Regards.
STTwo-32
2024-05-29 04:35 AM
Hello @Jt1002
Best Regards.
STTwo-32
