while i was trying to run example code from cude ide following message popes up what to do ?
JNAMB.1
Error in final launch sequence:
Failed to start GDB server
Error launching GDB server. Session terminated
Cannot run program "C:\ST\ST
5 REPLIES 5
Romain DIELEMAN
Could you give more details on your issue ? What version of CubeIDE are you using ? How did you start your project ? What are you trying to do ?
/Romain
Romain DIELEMAN
I have found this post on Community that resemble your issue. Does it apply to your scenario ?
/Romain
JNAMB.1
yes it helps , i also use avast free anti-virus, thank you
Did it solve your issue ? If yes could you select the previous message as "Best Answer" so that people facing the same issue will refer to the linked post.
/Romain
GFrid.2
Check for proper placement of the target board's power supply jumper, often labeled with selections: E5V, STLK, USB.
