what is the procedure to use STM32H750VB with touch GFX
NGond
5 REPLIES 5
Martin KJELDSEN
Chief III
Hi @NGond​,
Actually, we just uploaded an H750 application template that should be available through the designer now. Check it out and let me know!
/Martin
Martin KJELDSEN
Chief III
This is the H750-DISCO, though.
Martin KJELDSEN
Chief III
To summarize:
The procedure for the STM32H750VB is the same as for STM32H750B. H7 graphics will not be available through CubeMX for a while, i think, so you cannot go that route. Are you looking at a custom board here?
/Martin
NGond
yes we are looking for the custom board , so if you have any suggestion or another stm32 ic for touch gfx purpose that you can reffer?
Martin KJELDSEN
Chief III
Hi @NGond​,
That depends on what kind of application you're trying to build (complexity of graphs, animations, ..., your project budget, etc. E.g. if you're building a simple thermostat application you probably don't need an H750.
/Martin
